rskrause and others - crank choice questions?
Old Jan 25, 2004 | 06:20 PM
  #16
Highlander's Avatar
I have eagle H... keep in mind that LJ did 600s with stock crank and rods!!! they did break though.. but he was hammering them...
My setup "shouldn't" break with good tunning... I has run HARD its miles... 5k miles or such...
No problems at all when I removed the pan for a gasket change!
You should be alright... I agree that if you want to pump A LOT more, get lunati pro mods...
The eagle H-beam should hold...
I did a search and the callies is a lot more expensive though...
Old Jan 25, 2004 | 06:58 PM
  #17
engineermike's Avatar
Originally posted by BBoyce
engineermike,
How much was removed from the journals on this crank?
Also, the description in the link you provided says it requires a counter weighted flywheel, will this work for an LT1?
Ben
In order to get .020" extra stroke, the center of the journal must move .010", which means that the ID side of the journal must lose .020", providing the OD side of the journal loses nothing.
Summary: the journals are .020" under.
An LT1 has a counter-weighted flywheel.
Mike
Old Jan 25, 2004 | 08:29 PM
  #18
BBoyce's Avatar
Mike,
Thanks for replying, How much would you take for it?
Ben
Old Jan 25, 2004 | 08:51 PM
  #19
My general rule is 50% new price.
New is $515, so I'll ask for $255.
Fair enough?
Mike
Old Jan 25, 2004 | 09:00 PM
  #20
Highlander's Avatar
mike let me know about the plate.. THanks
Old Jan 25, 2004 | 09:27 PM
  #21
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
I've been using the same eagle crank and rods for a few years now.
So far so good.
Old Jan 25, 2004 | 09:33 PM
  #22
Highlander's Avatar
Hey intimd8
Do you have some sort of code on your sig that makes your RWHP go up every day??? you are at 744 already!! DAMN!!!!
Old Jan 25, 2004 | 09:48 PM
  #23
INTMD8's Avatar
Originally posted by The Highlander
Hey intimd8
LOL, no, I just spend alot of time trying different parts and tuning on the dyno. Last run was #144
Old Jan 26, 2004 | 12:22 AM
  #24
BBoyce's Avatar
Mike,
I'll have to check the budget, I'm still trying to recover from Christmas.LOL
Ben
Old Jan 26, 2004 | 11:37 AM
  #25
BLOWNBIRD's Avatar
Originally posted by marshall93z
how tough is the gm forged crank?
I made 928 fwhp using a GM forged crank. I am always thinking about it when I run the car... It has impressed me so far!
Feffman
Oct 9, 2015 05:42 AM
transam_388
Mar 15, 2015 11:53 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
