RPM limit of ATI P-600B
Re: RPM limit of ATI P-600B
The P600B is a "stock" head unit. I wouldn't spin it past the factory rpm limit. I had mine rebuilt twice (the first time had all the fancy upgrades) tring to get the boost numbers that I was told the pulley combo I was running would make.
J
J
Originally Posted by KS91Z28
Impeller RPM = Crank diameter divided by Blower Pulley diameter x Gear Ratio of the blower (3.05) x Engine RPM.
Max Impeller RPM for a P600B is 60,000
There's the table:
http://www.procharger.com/models.shtml
Originally Posted by SteveLT1
wow cj can you list some specs as to how you got that amt of horsepower from a p600b . those are some great numbers
man if i can get 500 hp at the tires as is ..with that blower i wont want to do much more....im assuming if i had head work done, i could pick up another 30 hp or so...i dont even mind if i lose some power down low..its already...blowin through the tires..no problem..some more midrange power...4000rpm and up would be nice..
Red_94Formula
Mar 7, 2015 09:21 AM
