Rotating procharger
Old Dec 10, 2006 | 12:08 PM
ForceFedZ's Avatar
Rotating procharger
Just installed a p600 on my LT1. I rotated the blower 180 degrees, done away with the intercooler and run straight methanol inj. only prob is now I cant get the belt tight enough cause rotating it lowered the pulley. The tensioner doesnt make enough contact to tighten the belt properly. Massive slip. Not sure if the SDCE setup will solve the problem. Has anyone heard of anyone else with this problem? Whats the cure? A homemade tensioner perhaps?
Old Dec 10, 2006 | 01:35 PM
Bayer-Z28's Avatar
Try www.ls1speed.com they make a billet tensioner. their Blown car had a problem with belt slippage too. Granted they went to a cog-drive, but still.
Check the site... that should help.
Old Dec 10, 2006 | 04:03 PM
30thTA0525's Avatar
did you flip the whole blower over in the brakets or did you just reclock it??
Old Dec 10, 2006 | 09:31 PM
Lonnie Pavtis's Avatar
If you flipped the blower so the transmission top is now at the bottom, I hope you reclocked the oil system as well. This needs done or it will not survive.
Old Dec 10, 2006 | 10:31 PM
ForceFedZ's Avatar
What do you mean relocked?
Old Dec 10, 2006 | 10:36 PM
ForceFedZ's Avatar
Oh my bad! reCLOCKED nah I did switch the mister and the drain around.
AviatorDave
Dec 19, 2016 06:35 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95blkss
Sep 22, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
