Bottom end parts to support 800rwhp.
Old Dec 1, 2006 | 11:11 PM
TransAm396's Avatar
All you guys making 800rwhp..describe the contents of your block. =)
Old Dec 2, 2006 | 07:55 AM
Eric@Victory Racing's Avatar
Callies Dragonslayer Crankshaft, Oliver Connecting Rods, Custom Diamond Pistons, Total Seal AP Series Rings, Callies Billet Splayed Main Caps, ARP Main Studs, Clevite Main Bearings, Clevite Rod Bearings, Clevite Cam Bearings.
Old Dec 2, 2006 | 09:50 AM
rskrause's Avatar
Moderator
Good advice. Lunati "Sledgehammer" is a viable crank option. Ross is another piston option as is JE. There are also other rod choices, but you won't go wrong with Oliver, for sure.
Rich
Old Dec 2, 2006 | 03:32 PM
TransAm396's Avatar
I apologize...I should of been a little more specific...components for a 355 (with a 5.7 rod). =)
Old Dec 2, 2006 | 07:08 PM
rskrause's Avatar
Moderator
Same answer.
Rich
Old Dec 2, 2006 | 11:33 PM
TransAm396's Avatar
What about program splayed caps,arp studs, eagle crank, Eagle H-beam(L-19's) and JE -22 dome pistons...with plasma moly rings?. . . . . . .
Old Dec 3, 2006 | 02:53 AM
engineermike's Avatar
Not quite 800 rwhp, but at 146 in the quarter, I'm sure it's comparable.
Program 4-bolt steel caps, ARP main studs, Eagle 4340 crank, Eagle 4340 H-beam 5.7's with ARP2000 rod bolts, Ross custom pistons, plasma moly rings.
After breaking 4 sets of SRP pistons last year, JE left a bad taste in my mouth. The Ross pistons are much healthier in the areas of concern.
Mike
Old Dec 3, 2006 | 11:27 AM
Lisa33's Avatar
Splayed main caps, ARP main studs, Eagle 4340 crank, Eagle 4340 H-beam 5.7's with ARP2000 rod bolts, SRP -31cc, plasma moly rings, clevite H series bearings, Cloyes True Double Roller timing chain set, melling oilpump and stock oilpan.
Not at 800 yet but planing to be there next year, upgrades this winter is moroso blockfiller and totalseal non gapless rings.
Old Dec 3, 2006 | 01:22 PM
TransAm396's Avatar
Mike
so plasma moly rings should handle it? Also, I was told the JEs are made of a better material than the SRPs.
Old Dec 3, 2006 | 01:57 PM
joe-96z1le's Avatar
SRPs = 4034 alloy
JEs = 2618 alloy
Old Dec 3, 2006 | 05:42 PM
cjmatt's Avatar
sounds alot like mine!!!!
Old Dec 3, 2006 | 08:38 PM
FastLt1's Avatar
Originally Posted by joe-96z1le
SRPs = 4034 alloy
JEs = 2618 alloy
Which is better? 4034??
Old Dec 3, 2006 | 08:52 PM
rskrause's Avatar
Moderator
The 2618 has very little silicon in it and is preferred for a blower application. 4032 and other aluminum-silicon alloys are more brittle, so though they have some advantages (such as lower thermal expansion) for very highly stressed parts the 2618 is preferred.
Rich
TransAm396's Avatar
2618 from what I hear
Old Dec 8, 2006 | 09:20 PM
mkent's Avatar
I called JE and discussed pistons with them. When I said 10-15psi, they immediately steered me away from the SRP (4034 alloy) and highly recommended the JE (2618 alloy). I then asked about the endurance of the 2618 alloy due to rumors pistons made of that material need replaced frequently and he said no, that is not a problem as long as the clearances are set to spec.
SRP's are apparently only safe for 5-8psi (mild boost as stated on the website).
And obviously without a good, safe tune and ample fuel supply, it won't matter what you use for alloy because detonation will own it.
