Relocating the waterpump?
Old Jun 27, 2005 | 07:37 PM
Rodrigues's Avatar
I would like to relocate my waterpump to a remote location to clear up some space. First I need to understand how the coolant flows through the block, why are there 4 ports on the lt1 waterpump? Which direction does it flow and which ports does it flow through?
Old Jun 27, 2005 | 08:03 PM
Lonnie Pavtis's Avatar
Re: Relocating the waterpump?
Coolant goes into the motor on the top ports up to the cylinder heads, returning from the block to the radiator on the bottom ports. A remote pump could be used with 2 supplies & 2 returns to the rad.
The complicated pump setup is due to the integral thermostat, which could be remotely mounted as well.
Old Jun 27, 2005 | 08:36 PM
Rodrigues's Avatar
Thanks!
Old Jun 27, 2005 | 09:43 PM
z28draco's Avatar
Originally Posted by Rodrigues
Thanks!
shouldve called me dick! lol
Old Jun 27, 2005 | 10:07 PM
96speed's Avatar
"BigRick" had a remote mount water pump setup on his car at thunder. Pretty interesting. He simply had some AN fittings welded into the block, and I believe it was a meziere remote water pump bolted to the driver's side frame rail.
Talk about a nice amount of $$$ in AN fittings for that job. Ouch!
Ryan
RUENUF
Mar 13, 2016 03:37 PM
reww86
Aug 29, 2015 06:04 PM
MikeWhitener
Aug 2, 2015 06:17 PM
Boss002
Jul 24, 2015 10:47 AM
