Realistically, how reliable are turbos on LS1s?
Old Nov 21, 2003 | 02:50 PM
  #16
magius231's Avatar
you can make either one last even with higher boost...boost doesn't kill pistons/rings, detonation does. If you wanted you could possibly run 12-14psi on a stock bottom end, but you would need good race gas, retarded timing, and probably alky injection to do it, and it would have to be WELL tuned to not blow it up.
There are some guys in GN's running 30+psi pressures on stock style cast pistons...they aren't hypereutectic, but they aren't forged either...they tune the CRAP out of them.
Old Nov 22, 2003 | 11:26 AM
  #17
supersp0rt's Avatar
my stock motor has survived since this past summer just fine. my qmp kit has been super.
Old Nov 23, 2003 | 10:45 AM
  #18
Whistler's Avatar
I guess this turned into another turbo LT1 vs turbo LS1 but FWIW...
Perhaps the reason an LS1 holds up better at higher boost/HP level is a combination of these things
1 Lower compression
2 Better PCM with dual central mounted knock sensors keeps a better handle on preignition, which is the reaper for either of these engines.
3 Better flowing heads which skews the boost comparision. An LT1 with 7 lbs of backpressure(boost) in the intake isn't getting the same CFM flowing through it as an LS1 with 7 lbs.
All that said if you're going to FI the LS1 with a stock bottom end the best thing you can do is pick up a set of the cheap and readily available 6 litre aluminum truck heads. These combined with a little thicker head gasket will get you close to 9:1 and flow even better than the regular 5.7 heads.
Old Nov 23, 2003 | 11:03 AM
  #19
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
FWIW, compression should never be dropped by use of a thicker head gasket.
Old Nov 23, 2003 | 11:32 AM
  #20
Whistler's Avatar
In theory no, but lots of people do it and it works.
I ran 15 PSI and over 600 RWHP for 2 years on a stock ZZ3 350 bottom end with big chamber AFRs and a double thickness head gasket to get the compression lower.
You can get cometic MLS gaskets for LS1 in just about any thickness you want. I wouldn't do too thick, say over .070
brothaslide
Jan 9, 2016 12:11 PM
karpetcm
Aug 14, 2015 03:02 PM
Jocofire1
Aug 7, 2015 03:16 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
mrwz28
Jul 8, 2015 09:11 PM
