Quick Spool
Old May 30, 2009 | 01:48 PM
boosted-lt1's Avatar
Quick Spool
Essentially an actuator controlled butterfly valve that can effectively halve your A/R ratio. So if you had a .96A/R you would be able to spool it like a ~0.48 until your preset and it opens up.
A divided housing is required.
http://www.fquick.com/videos/Sound_P...ool_Valve/7761
Anyone have anything to add on these?
-Scott.
Old May 30, 2009 | 05:00 PM
MikeGyver's Avatar
Varying duty cycle to vary the blade?
Just use an actuator from a wastegate with an internal spring. Have boost pressure fight the spring to overcome it as boost rises. Essentially wastegate controlling half the turbo. Boost pressure will shoot up then dump through the other side of the turbo as flow increases. Also in the event that the blade fails closed, make sure you're wastegate is large enough to dump all the exhaust so you don't overboost.
Old May 30, 2009 | 05:45 PM
That's pretty much it. Here is some info on a rear mount setup.
http://www.ls1tech.com/forums/forced...ke-graphs.html
Here is a graph from a supra.
http://www.fbody.com/anything/1006103
-Scott.
Old May 31, 2009 | 10:41 PM
crazycat's Avatar
This set up sounds good , Iam thinking about trying it out.. I have a t6 flange with a
1.19 a/r so it should help alot.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
