question about Boost and PCV valves
Old Jan 7, 2012 | 10:40 AM
NJ-LE's Avatar
Question question about Boost and PCV valves
Are the PCV valves for the supercharged Buicks (GNX?) and Pontiac Sunbirds (Solstice GXP?) different from the unboosted ones? Do they have an air tight seal against backflow or like all other PCV valves allow a very small amount of reverse flow?
Last edited by NJ-LE; Jan 7, 2012 at 06:14 PM. Reason: ooops ... meant Solstice but had entered solara!!!
Old Jan 9, 2012 | 12:12 PM
NJ-LE's Avatar
Re: question about Boost and PCV valves
anyone have an info?
Old Jan 9, 2012 | 08:16 PM
Kevin Blown 95 TA's Avatar
What some of us did was use a brake booster check valve going into the bung below the throttle body - the pcv valve just stayed in its normal location. So when the manifold was under positive pressure (boost), it closed the check valve, but when it was negative pressure (vacuum), the valve opened and the pcv worked like normal.
Old Jan 10, 2012 | 11:26 AM
NJ-LE's Avatar
Kevin Blown 95TA:
Thanks for the tip! That sounds like a very good solution. I'll try that. Since I have already moved my PCV and fitted a knock-out to keep fugitive oil out of the intake, inserting one will be easy. Since the "normal" flow direction through the stock and alternate PCV valves seems to have no noticeable restriction, I wonder if a PCV valve is even necessary! Hmmmm ... I might try that too and see what happens.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
