Q: What do you do after many thousands of dollars end up in a toasted motor?
Old May 31, 2003 | 07:28 PM
Slo-ride's Avatar
A: Go buy another toy! Something a bit more reliable I might add:
http://groups.msn.com/Slorides1997Po...oto&PhotoID=63
Speedy is going to take a backseat to Bumpy for a little while.
Old May 31, 2003 | 09:28 PM
Fast Caddie's Avatar
Yea, then after many more thousands of dollars in mods to the Jeep and you take it rock climbing for the first time and roll it down the hill LOL
Old May 31, 2003 | 09:29 PM
It's Cochese!'s Avatar
Nice TJ man. If you need any advice on how to mod it, nearly anything, I'm your guy. Just hit me up thru PM or email.
Old May 31, 2003 | 10:49 PM
BPS's Avatar
BPS
Funny, I've been looking at buying a TJ as well!
Nice wheels - should be fun
Old May 31, 2003 | 11:34 PM
Slo-ride's Avatar
Fast Caddie, that ain't funny, man.
Cochese, I may take you up on that.
BPS, thanks, man. It's gonna be a lot-o-fun. Therapy, I would call it. Get my mind off the TA.
Old Jun 1, 2003 | 12:14 AM
97TA-WS6-Con's Avatar
We have a similar set up but I lost track of what your currant status is.
Obviously not good.
Just the Coles notes revsion, what is happening now?
Old Jun 2, 2003 | 07:38 AM
stewmeistr's Avatar
Do yourself a favor and don't mod it.. or do the stuff that doesn't cut you out of a warranty etc...
I've spent too much down time with modded cars and now that we have a stock running one I'll never have another car thats not plain jane reliable STOCK in the stable.
My .02,
STEW
Remember the Rule of the 3-F's.
If it Flys, Floats or F()cks... rent it. Its much cheaper.
Old Jun 2, 2003 | 08:20 PM
Slo-ride's Avatar
Good advice, Stew. I won't do anything too radical. Cold air induction and catback maybe. I've learned my lesson with the T.A.
97TA, here's the short version:
Blew intake gasket on dyno.
Replaced that gasket, new ARP head bolts, 1.6 Crane Gold RR, installed KB boost-a-pump, new plugs, wires, leak down test, adjust valves that were ALL OUT OF WHACK.
Leak down test revealed some issues. Decided to go for it anyway. At the track the car keeps spitting and sputtering past 4,900 rpm. FINALLY figure out that it's the coil and wire. Fix that. Car makes it to 5,900 rpm(test driven by shop co-owner). Good boost, good AFR, 72# injectors are maxed, though. Car is taken back to the shop. I get a phone call, not good news. LOTS of blow by. Drive car home sounding like shiot. Park it.
I intend to pull the motor and go back through it with different pistons(lower CR from the now 10:1), bigger cam(224/236, .536"/.555", 114), go back through the heads again, improve the fuel system.....AGAIN, and hook the nitrous back up. Using the F.A.S.T. nitrous controller, I should be able to make the 15lbs of boost and run a 150 shot successfully. I hope.
Until then, I'm going to do a little Slo-riding in the Jeep.
Old Jun 2, 2003 | 10:29 PM
That is the cam I have. I'm still tuning with the FAST and I have 75# injector. I haver some AFR 190 heads ported of course and CR is 8.9:1
However, No nitrous in my plans for the time being. I only want to go 11.00. Any faster and I have to pull out the chrome 5 point and get a 10 point. Not interested in that.
Good luck though.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Gtpguy
Jan 26, 2015 04:50 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
