Pump Location
Old Sep 30, 2007 | 06:56 PM
thirdgen327's Avatar
Pump Location
Where are you guys mounting your injection pump for water / meth injection? Pretty tight in the engine compartment as you well know.
Old Sep 30, 2007 | 07:23 PM
Kevin Blown 95 TA's Avatar
Mine ended up in the fender space in front of the left front tire.screwed it to the bottom of the sheetmetal that the original filter box was set into.
Old Sep 30, 2007 | 07:41 PM
roguedriver's Avatar
Mine is right there under the headlights on the outter frame rail. Seems tight but theres plenty of room there without my intercooler piping. You can get to it also if you pull the plastic off from underneath.
Ken R.
Old Sep 30, 2007 | 09:03 PM
Thanks guys.
roguedriver, PM sent.
Old Oct 1, 2007 | 06:45 AM
97WS6Pilot's Avatar
I put mine on the passenger side in front of the front fender well. Lots of room there. I had to relocate the horn but it was no big deal. I didn't have enough room in the driver side because of my custom air intake and air filter.
Old Oct 1, 2007 | 07:47 AM
Are you guys using the factory washer fluid tank? I think that would make for a clean install and obviously holds much more than the tank from snow.
Old Oct 1, 2007 | 10:55 AM
97WS6Pilot's Avatar
Yep, I used the alkycontrol kit which uses the W/W reservoir . It also has a low level sensor/led and light that comes on to verify the pump is reaching full pressure. It was plug and play.
Old Oct 1, 2007 | 02:59 PM
Factory washer tank here. It holds about 1 gallon.
Ken R.
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
