PTK or Turbo Tech??
Old Jan 5, 2004 | 01:00 PM
93M29FOURMULA's Avatar
PTK or Turbo Tech??
Out of the two "normal" turbo kits, which do you think is better? They both seem like good kits with the turbo tech being about 500 less and comes with an air-to-air intercooler. Does any body know the power numbers produced out of each? If you haven't seen the turbo tech kit check out detroitspeedworks.com Lets hear what everybody thinks.
Old Jan 5, 2004 | 01:52 PM
mongse_1's Avatar
Not sure if TT has changed their design, but the downpipe was very small on the original design. I'd go PTK, but that's me. I know of at least one guy on the board w/ the PTK setup.
Old Jan 5, 2004 | 03:36 PM
racr4jc's Avatar
I'd go PTK....
Old Jan 5, 2004 | 04:26 PM
Chrisbequick's Avatar
PTK uses tubular headers instead of a stock manifold and a log turbo manifold, and uses a 3" downpipe instead of a 2.5" downpipe.
FWIW- I'm using PTK's headers, crossover pipe and intercooler and building all the piping and 3.5" downpipe.
-Chris
Old Jan 6, 2004 | 01:15 AM
Jesse_Boyer's Avatar
i'm running a TT manifold and xover. made my own 3 inch dp
FYI: i'm going to be replacing the TT manifold with a custom tubular unit. Should see some excellent gains
Old Jan 6, 2004 | 04:40 AM
SMOKNZ's Avatar
Nothing but problems with the TT setup trying to make bigger HP numbers. If all your looking for is 100Hp and never want more then this kit may be OK, but nothing more. I was always having problems getting exhuast manifold gaskets to seal, had the header crack on me, and when running high boost (16-18psi) I was getting coolant seepage from the head gaskets even with a 1074 gasket and ARP bolts, with stock bolts and gaskets I just stretched the bolts and resulted in a release of coolant in my engine bay at the track none-the-less.
I sold the kit, and am making a twin kit. I'm hoping to be much happier!
Bill
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
