Turbo guys here... Oil out exuast? STS?
Old Jan 3, 2004 | 04:20 PM
262guy?'s Avatar
Unhappy Turbo guys here... Oil out exuast? STS?
Well i just got done installing a 14b mitsu turbo on my winter beater ( 94' 2.2l s-10). I fire it up to find out that oil is spewing out of the exuast side. I am wondering if I have to run some sort of pump on the return cuase its going up hill a litlle. Any help is much appreciated.
How do the STS kits get oil back to the pan all the way from the back?
Old Jan 3, 2004 | 05:31 PM
Tiago's Avatar
the oil drain is gravity fed!!!
if you have it going up it will completely leak past the seals into the exaust without hesitation.
you must have the drain going down or utilize a oil scavaging pump. There are options out there.
Old Jan 5, 2004 | 07:13 AM
262guy?'s Avatar
I think I might try a holley blue pump for the oil return. I hae one laying around. I was hoping someone with a STS kit would chime in with some info on there return setup.
Old Jan 5, 2004 | 07:43 AM
Tiago's Avatar
they use a scavange pump to pump oil back to the motor.
Old Jan 6, 2004 | 01:19 AM
Jesse_Boyer's Avatar
<---- had to use a scavaging pump on my setup
Old Jan 6, 2004 | 10:59 AM
262guy?'s Avatar
What kind how much?
Old Jan 6, 2004 | 01:22 PM
ToddR's Avatar
Here are a couple links by engineermike on another post.
http://www.mrturbo.com/parts/109.html
Scavenge pump
http://www.batinc.net/files/pump.pdf
Electric Fluid Pump
Ones 90something and the other is in the 180's.
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
artic94
Jan 17, 2015 11:19 AM
Red97LT1
Aug 7, 2002 05:45 PM
