PTK Turbo
Re: PTK Turbo
Originally Posted by JZ 97 SS 1500
I picked the cam, and do most of the time for my customers, but the heads, have no idea. But with stock valves, they aren't going to flow any crazy numbers. Probably 240-250cfm.
Jose
Jose
Isn't that about the same "size" cam INTMD8 uses?
Re: PTK Turbo
Not sure if Jim is using that cam or not.But its probably pretty similar since I think Jim said it was a small cam. You can't get much smaller then that..lol. Reason I chose that cam though, was the owner said his exhaust runners were not worked much on. Also the LT1 doesn't flow as well on the exhaust side as an LS1 which you can run a reverse split with great results if using a true turbo header system. On the LT1 with the exhaust runner not being worked much I like to hang the valve open a little longer on the exhaust as long as the system is running an efficient turbo and header. Now if the design of the turbo system uses a log manifold, then I run a reverse split, even if the exhaust port flows great. Reason being is a log manifold elavates exhaust backpressure substantially which can lead to reversion.
Jose
Jose
Re: PTK Turbo
The owner dynoed his car yesterday....he called me with the #'s are below. I'm wondering what a T88 would do in its place. I am thinking of sending him my T88 and 3" dp to test it...hmmm
Results were with C16 and straight ice water in IC @ 18psi. The ice water fudges the correction factor a bit, but I calculate probably 15-25rwhp less.
828rwhp@5700rpms
878rwtq@4300rpms
Jose
828rwhp@5700rpms
878rwtq@4300rpms
Jose
Re: PTK Turbo
828rwhp@5700rpms
878rwtq@4300rpms
Jose
828rwhp@5700rpms
878rwtq@4300rpms
Jose
Re: PTK Turbo
828rwhp@5700rpms
878rwtq@4300rpms
Jose
828rwhp@5700rpms
878rwtq@4300rpms
Jose
Simply incredible, what does his fuel system look like to support those numbers?
Re: PTK Turbo
828rwhp@5700rpms
878rwtq@4300rpms
Jose
828rwhp@5700rpms
878rwtq@4300rpms
Jose
I too would like to know how he did his fuel system.
Re: PTK Turbo
He copied my fuel system which is simple and consists of just dual inline HP 255 walbro's, sumped tank, 10an feed, 6 an return, 72lbs deka's and the fuel rails modded for the AN fittings.
Jose
Jose
Re: PTK Turbo
BTW, he is going to run it with that setup this weekend and try some other things for me. I hope the drivetrain doesn't take a dump. He is still running the stock 93 6spd which isn't as strong. So cross your fingers....lol
Jose
Jose
Re: PTK Turbo
No its a 4 bolt splayed conversion. I don't think I would push the stock 2 bolt that far, but that is just me. I have some pretty crazy customers though that do some questionable things...lol
Jose
Jose
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
