ProTurbo kit installed on LT1
Old Jun 8, 2003 | 05:39 PM
  #16
OUTCAST's Avatar
Originally posted by got_hp?
wow!!!!!!!..........thats very impressive on the stock motor.......although im guessing 11psi is pretty dangerous for those insternals.
are you using PTK's FMU that comes with the kit? how is your A/F ratio? are those runs after tuning with LT1edit?
do you have a dyno graph of any runs? id really like to see what it looks like at 5-7psi.........thats probably what people will be running on the street.
with heads/cam/forged pistons, this kit looks like it would be a killer.
Originally posted by 96TurboTA
sweet, glad it's working out. Does the turbo heat up the radiator at all?
Originally posted by Wild1
Were you sweating when the boost was turned up to 11 PSI on a stock bottom end? Congrats...
got_hp
Yes is was and stopped the run early when it went to 11psi.
I am using the FMU that they supplied.
A/F was good around 11 peek at 12 and stopped when we saw timing being taken out.
We did use LT1 edit and it is nice.
Going to get some 101 fuel and dyno at Powerhouse in MWC in OK will put up graph for you.
I think it will be too just working with it.
96TurboTA
I am not sure, but that has crossed my mind. It get hot sitting with just the two pusher fans. Got a BeCool 13in puller I will install this week to see if that helps. If not next step is a Be Cool radiator. I will keep you up dated. I did not install it since ProTurbo used my car as a test project. Did not have my car for months, but it looks like it was worth the trouble.
Wild1
Yes I was and we aborted the run, but man it was nice. Will not do that again until the bottom end gets update!
Old Jun 8, 2003 | 06:08 PM
  #17
Wild1's Avatar
Way to go... let us know when the kit is out. By the way, when you do build a stout turbo motor, what specs will you build it to? Comp ratio, cu in, etc..
Old Jun 8, 2003 | 08:54 PM
  #18
RichJ's Avatar
Very impressive! What turbo did you go with? What are you using to retard timing under boost?
Looking forward to seeing the dyno plots!
Old Jun 9, 2003 | 09:56 AM
  #19
LT4POWR's Avatar
awesome results
Old Jun 9, 2003 | 11:00 AM
  #20
JZ 97 SS 1500's Avatar
Great #'s man. I hope to have mine running soon, just waiting on the last batch of parts to arrive.
Jose
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jun 23, 2016 08:42 PM
CARiD
Jan 14, 2015 04:00 AM
Dec 4, 2014 11:56 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
