Project BoostedROC....Iroc383LT1 Turbo Build.
Old 11-02-2008, 12:13 PM
jay_rich's Avatar
Well I have posted on a couple boards and may as well post on here since there are a hand full of LT1 3rd gens on here that are doing a FI setup.
I tore out some parts that were in the way for mock up today. I decided to go back to my old idea since the turbo fits perfect in place!
Well here are some pics before..then the slooooow transition.
Plans.
Run 12lbs boost on 94 octane WITH Meth
Specs.
383 LT1 (oringed)(9.78:1 comp)(downfall)
4 Bolt Splayed Mains
Eagle 3.75 Crank (forged)
Eagle H-Beams (Forged)
JE -28CC pistons (forged)
LE2 Ported heads
1.6RR
Cam (custom still awaiting)
Ported Intake
58mm TB
Double Rollar Timing Chain
Electric Water pump
7.5 Quart Pan
TURBO
Garret/AiResearch TH08A64
74mm Turbine
.96 A/R (hot)
.95 A/R(cold)
T6 Flange
Also doing...
Dual walbro 255s
-10an feed/return Braided
-LS1 front brakes
-Line Lock
-Complete front to rear brake lines
-Paint the entire engine bay Black
Enjoy!
I will update as much as possible.
Jay
IMGP2978.jpg?t=1225330041
jay_rich is offline
Old 11-02-2008, 01:18 PM
slomarao's Avatar
goals for the setup?
slomarao is offline
Old 11-02-2008, 02:02 PM
jay_rich's Avatar
550-600 RWHP and run like mid to high 10s.
Jay
jay_rich is offline
Old 11-03-2008, 08:52 AM
Tricked-Out-Toy's Avatar
Nice! what made you go to putting it on the pass side? I looked long and hard at that and chose the opposite side. there just seemed like there was more room on the driver side to get the cross over and down pipe through... Im intersted to see how yours comes out since It was one of the ways I was planning on doing mine.
Ill have to post up my build thread see who gets done first!
Tricked-Out-Toy is offline
Old 11-03-2008, 08:54 AM
jay_rich's Avatar
I am still gonna be running the DP on the driver side. Its gonna run across the motor bc its 5.125 inch.
And I be u will be done before me :P...after this weekend the car will be covered for the winter.(im doing all this work in a driveway lol.
Jay
jay_rich is offline
Old 11-03-2008, 09:08 AM
Jay
are you necking the DP to a 4"? and if you saw my car you would probably change your mind! Ill take some pics tonight ans start a build thread..
Old 11-03-2008, 10:01 AM
jay_rich's Avatar
Yes I will be necking it down, probably to a 3.5inch.
Jay
jay_rich is offline
Old 11-08-2008, 11:14 AM
Orr89rocz's Avatar
Nice build setup! i would think with 12 lbs you'll be over 600whp tho
Orr89rocz is offline
Old 11-08-2008, 02:56 PM
jay_rich's Avatar
Well more progress done..
I got excited this morning and pulled it by myself lol.
Jay
jay_rich is offline
Old 11-13-2008, 02:26 PM
jay_rich's Avatar
Picked up a griffen 4 core rad today. I couldnt stand tryin to figure out where to mount the turbo and it looking good so the stock rad had to go.
I just took pics of where it will be not any cutting until i know for sure.
Jay
And the 383 LT1 tore down getting ready for my new Comp custom grind to go in .
Also I am repainting the block red, valve covers black, intake red and accessories silver.
jay_rich is offline
Old 11-19-2008, 12:16 AM
jay_rich's Avatar
Well not much interest I see but ill keep posting :P..
Cam, injectors and LS adapter plates are in!
Cam has the wrong dowel tho them bastards!
Jay
jay_rich is offline
Old 11-19-2008, 07:58 AM
Im still interested!! for some reason it didnt tell me the thread had been updated. parts look good. what are the specs on the cam?
Old 11-19-2008, 10:03 AM
camarobird92's Avatar
Don't get down, Jay... I'm interested in your build... lol
camarobird92 is offline
Old 11-19-2008, 12:31 PM
jay_rich's Avatar
Woot 3rd gen guys lol
Cam is
230/236
.544/.555
114LSA
Should do the trick. I emailed comp about my dowel and they said they will get back to me.
Jay
jay_rich is offline
Old 11-21-2008, 01:45 PM
jay_rich's Avatar
Well i started painting some parts. The oil pan still neds to come off so i didnt bother taping it off, since it will be repainted, and the Oil drain needs to be put in.
Tomorrow is cam install and assemble the motor.
Jay
NOTE THE FINS ON THE TOP OF THE INTAKE WILL BE POLISHED SO ITS NOT SO...RED LOL.
jay_rich is offline
Quick Reply: Project BoostedROC....Iroc383LT1 Turbo Build.
