Procharger on stock LT1, worth it ?
Old Dec 22, 2004 | 09:21 PM
  #16
ATMINF's Avatar
Re: Procharger on stock LT1, worth it ?
I put mine on several years ago, and based on my motor and SC setup, I will say that above anything else you need to insure that the engine is dyno tuned. This is the only way the setup will make good power and be reliable. And as I stated in past posted, I am one of the few people that can say that they have had close to 90,000 miles of running a SC on a stock motor. The only reason why it finally went bad is the diaphram in the FMU went bad and the motor got lean and I cracked #1 & #7 ringlands. Good Luck.
Old Dec 23, 2004 | 10:19 PM
  #17
purple95formula's Avatar
I have 8lb system with intercooler mounted under front end. Did alot of research before I bought.Had my tuning done by PCMforLess mail order and Brian recommended going with 42lb injectors to eliminate FMU and leave some room for future HP.I haven't had it on dyno yet but,also haven't had any problems yet.
Old Dec 24, 2004 | 07:02 AM
  #18
DJ:BOTA's Avatar
From: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
Worth it...............hell yes! Just be ready to rebuild. Mine lasted 1 month or a 1000 miles before it cooked 2 pistons.
They #'s are in the sig below on the stock motor. The car now has 8.5:1 comp, and is a beast! The newest #'s are 425rw, 406tq, and that's maxing the fuel system right now.
Boost is addicting!
Old Dec 29, 2004 | 07:53 AM
  #19
Hybrid86Z's Avatar
i'm also looking at a supercharger. I would most run a methenal or propane injection to help out on intake temps, but only run 4-6 psi on my engine.
is there anything we can do as far as headgaskets to lower compression a little bit? just a thought
btw, anyone have a used setup for sale under 2 grand? I'm now looking for a good kit to buy.
D1SC383LT4
Jan 1, 2016 01:56 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
