Procharger F1
Procharger F1
Well, it's almost done. All I can say is that the F1 really "sucks". After tracing a low boost condition to the three inches or so of orange "dryer hose" ATI supplied used to mate the hard rubber intake part to the blower we fabbed a rigid (metal) replacement. This got us boost up to 5,200rpm instead of 4,500. But at that point, the remaining intake pieces also collapsed
. So now it's one more fab job and it will finally be really and truly done.
I think it will all be worth it though. We tested it in speed density mode and with no intake restriction, it made 22psi at 6,000rpm and was still rising. Even with a loose converter/automatic combo it made good hp. And that was without the N2O. But if you think of a Procharger F1 on a 4th gen. LT1, think again. It is far from a "bolt on".
Rich Krause
. So now it's one more fab job and it will finally be really and truly done. I think it will all be worth it though. We tested it in speed density mode and with no intake restriction, it made 22psi at 6,000rpm and was still rising. Even with a loose converter/automatic combo it made good hp. And that was without the N2O. But if you think of a Procharger F1 on a 4th gen. LT1, think again. It is far from a "bolt on".
Rich Krause
Damn Doc!! That's 440hp worth of power adder alone, before N20!! You'll be in the 8's for sure!!
Btw- do you have any pics of your orange tube replacement? How long did it take to make? How'd ya do it?
Hope all is well-
Floored in Buff,
Drooling Steve
Hope all is well-
Floored in Buff,
Drooling Steve
There is some of what mine looks like. I wish I could get it up higher to get a better pic of it. I'll see if I can't get it on a lift and get some more pics of it. There are more pics in my sig.
I believe its 3.5" all the way to the blower, then it goes to 4" right behind the intercooler and into a 4x8.75" K&N filter.
Hope all is well-
Floored in Buff,
Drooling Steve
Hope all is well-
Floored in Buff,
Drooling Steve
Hope things are good with you as well. You should come over for a cigar sometime.
Rich Krause
We'll get together soon bud.
Steve
Originally posted by IDOXLR8
rskrause :
Are you running a 12-rib setup with your car?? Did you have any problems with getting your crank pulley to align with your blower pulley??
rskrause :
Rich Krause
Trust me I know. I have been their
Do you remember how thick of a spacer you had to use? I am currently running a single 6-rib belt on my car because I my misalignment issue.
Rich Krause
Originally posted by Derrick Redd
Can't wait to see some dyno #'s and track times on that beast.
Rich Krause
Originally posted by aggiez28
any predictions on times??? or hopes ??
doesn't it? The high mph relative to ET was a function of granny shifting the T56. Rich Krause
