Plugs for a blown 383 with Nitrous
Hi guys,
I currently have a 9lb non-intercooled S-trim setup, and want to spray a 75 shot on top of that for a little cooling
. I will probably be pullying up to 12lbs in the near future
My motor is a 8.5:1 fully forged 383 with 50lb injectors.
Should I run NGK tr6's, autolite 103s, or a colder plug? Also what should I gap them to?
Thanks for the help folks!
. I will probably be pullying up to 12lbs in the near futureMy motor is a 8.5:1 fully forged 383 with 50lb injectors.
Run a very cold plug, much colder than a TR6 or Autolite 103. I am running an NGK with an "11"00 heat range, which is 5-6 heat ranges colder than a stock plug. The center electrode is basically flush with the plug flange. They are gapped at 0.035" and I have had no fouling problems with a Crane box and Accell coil, stock wires. The plug pn won't help 'cause they are for AFR heads.
Rich Krause
Rich Krause
Well I have AFR 220s.... hand over that pn! hehe.
So what are the options that aren't quite as cold as your NGKs, yet colder then Autolite 103s and NGK TR6s? I know you are setup for 750-800'ish rwhp - I am looking more into the 550-600 rwhp range on 94 octane so I do not think a 11 heat range plug would be optimal...
Thanks again!
Thanks again!
Thanks again!
Thanks again!
Rich Krause
Originally posted by Chris B
Isn't the normal LT1 plug a .708 reach? Do the AFR's take a slightly longer plug, or do the extra 40thou not really make a difference?
thanks,
Chris
thanks,
Chris
Rich Krause
Drtryder
Apr 22, 2015 04:17 PM
