Piston Questions
Old Jan 30, 2003 | 11:31 AM
Ultra_Dog's Avatar
Piston Questions
I am about to tear into the engine and replace the pistions. I belive I broke a ring land, because of high crankcase pressure and rough running.
I have researched JE pistons (Extreme Duty inverted dome) #131636 that are forged and has a -22cc dish. Even with that dish, my LT4 heads (54.4 cc) will be putting out close to 10.0:1 CR. I can have custom pistons made to about -33cc, that will bring my CR to about 9.0, assuming deck height and head gaskets are normal. If I go that route, there are a lot of additional variables, such as ring gaps, and types of rings. I am considering 6.00" rods, but I understand they rob from low end and give to high end.
I am all ears to suggestions and experience.
I have an ATI 8# SC and want this to be a daily cruise missile, not an Atlas booster rocket.
Joe
Old Jan 30, 2003 | 02:02 PM
IDOXLR8's Avatar
HOw much boost are you looking at pushing?? Are you going with a stroker or just boring it over .030? Ideally you want anywhere from 9-9.5:1 compression. For my setup I went with -31cc JE pistons, and 5.875 OLiver Rods. I had my heads hogged out to 58cc. This gave me a compression around 9:1. Personally I would go with either JE pistons or SRP
Old Jan 30, 2003 | 03:45 PM
rskrause's Avatar
Moderator
What cam are you running? What really counts is dynamic CR, not static CR.
Rich Krause
Old Jan 30, 2003 | 07:32 PM
ttokarcik's Avatar
I replaced my pistons with TRW's Speed PRO Blower/Turbo pistons and to get the CR where I needed the builder removed material from the walls of the dish in the piston, (made the dish bigger). This may be an option for you also?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Sergio
Jan 27, 2016 04:27 PM
Dmonty
Jun 2, 2015 11:19 PM
1963SS
Feb 6, 2015 10:05 AM
