Picture of my dual walbro setup
Old Sep 19, 2006 | 05:05 PM
  #151
blown383's Avatar
Re: Picture of my dual walbro setup
If you take a close look at xxxsaintxxx's picture you can see a close up of how the flex tube is attached to the y-block. It looks like a metal band clamp.
-B
Old Sep 20, 2006 | 06:04 PM
  #152
97WS6Pilot's Avatar
Yes, I see that, but how is the Y block attached to the metal feed tube?
Old Sep 20, 2006 | 07:21 PM
  #153
Roadie's Avatar
It's just a brass compression fitting for 3/8" OD tube. You can pick one up for a couple bucks at your local home depot... In fact, there's only about $10-12 in fittings in the tank there.
One thing they did right was to chop off the end of that feed tube first. The first half inch of the feed line is only 5/16" OD.
Old Sep 27, 2006 | 06:37 AM
  #154
97WS6Pilot's Avatar
I think I may make this mod to mine. It looks like it would fit in the tank easier. Also that flex hose will last forever as opposed to rubber intank hose.
Old Oct 30, 2006 | 09:13 AM
  #155
97WS6Pilot's Avatar
OK, here it is. The final iteration of my dual fuel pump. Complete with a Pave hermetically sealed bulkhead connector, dual flex hoses, and brass T fittings. The rubber lines were chaffing on my initial setup. I don't know if they would have eventually ruptured but I wasn't taking the chance on being stranded somewhere.
Old Nov 4, 2006 | 05:33 PM
  #156
ronbros's Avatar
wiring
Why couldnt you just run two pumps all the time, just asking, what is the pros and cons. Ron
Old Nov 4, 2006 | 08:43 PM
  #157
Roadie's Avatar
I am... There's no problem as long as you have a big enough regulator to handle the flow... If you run dual pumps on the stock regulator, the fuel pressure will creep up when not using a lot of fuel.
Old Nov 6, 2006 | 05:15 PM
  #158
95 Z/28 LT1's Avatar
Super Moderator
Running two pumps all the time will heat the fuel up as well.
Old Nov 6, 2006 | 11:42 PM
  #159
Roadie's Avatar
yeah, but not as much as you think... The fuel gets heated more by picking up heat in the rails (engine heat) and bringing that back to the tank.
I do keep my tank over half full all the time, but that's to aid traction more than anything else.
Old Nov 16, 2006 | 02:42 AM
  #160
97WS6Pilot's Avatar
He has a point. It doesn't take much to rewire that thing. The boost switch is very inexpensive and comes on at about 5 psi instead of all the time.
Old Nov 16, 2006 | 12:23 PM
  #161
jasonisdn's Avatar
what are most of you using to seal the holes for the new wires on the second pump. i am ready to finish this part of the car, thanks guys.
Old Nov 16, 2006 | 11:41 PM
  #162
97WS6Pilot's Avatar
I did it two ways and both worked well.
1. Nylon bolt and nut with a hole through the bolt sealed with Proseal.
2. Hermetically sealed fitting with O ring from Pave Technology.
Number 1 is cheaper.
Old Jan 29, 2007 | 08:22 PM
  #163
97WS6Pilot's Avatar
Another update. I pulled out my walbro setup and did some tweaking and inspection(and tightened the band clamps). Afterward, one of the pumps on my setup was not holding pressure under load. I tracked it down to the clamps that hold the pumps to the fuel pump assembly.
If you tighten the band clamps too much it will restrict flow from the pumps. Also it is best to move the band clamps to the top of pumps. Band clamps around the bottom of the pump are more restrictive than band clamps at the top of the pump. I found this out by testing the fuel pressure with the clamps in different locations. The ultimate setup would be to get rid of all the band clamps and have a plastic holder of some sort.
Old Jan 30, 2007 | 01:32 PM
  #164
ZBLKHELLRZR's Avatar
That's a nice piece of info to have 97WS6Pilot. Thanks I'll keep that in mind!
Old Feb 4, 2007 | 04:04 PM
  #165
will62085's Avatar
Originally Posted by GetaZforgetGT
Any one know Geoff Chadwick?
He built this
Notice the bulkhead fitting and the larger feed lines.
Not that i really care, but just to clarify...thats me, and that is my pump setup i built about a year and a half ago.
