Picture of my dual walbro setup
#136
Re: Picture of my dual walbro setup
Just wanted to give an update on my dual walbro setup. I recently was having some unexplained missing in my car. When I checked my pump setup I found that the tank was not pressurizing like it should. My JB weld was not holding pressure where the wires enter the tank.
This was causing the fuel pump to cavitate or make air bubbles in the lines. I put a Nylon bolt fitting and O ring like shown earlier and sealed it with ultra copper and now the problem is fixed. Apparently the tank must pressurize to 5psi to allow the pumps to not cavitate.
#137
Thanks for the bit of info 97WS6Pilot. I think I may be in the same boat as I swapped sending units and had to remove the wiring and reinstall and it wasn't quite as snug as the original setup.
#138
#139
Originally Posted by Ponyhntr
So what is actually pressurizing the tank? This may be the problem I am experiencing (stumble in upper RPM's). I don't have any of the EVAP lines hooked up anymore. How is yours?
I know on turbine engines there is always a fuel boost pump to aid the main engine pump and prevent cavitation. I think in this instance GM pressurizes tank to aid the fuel pump and also to prevent so much fuel from vaporizing in the tank. More pressure = less vapor.
#140
how did you know you needed to run two pumps? i'm running 8psi with 42lb injectors and one 255 walbro. when my 355 is done i plan to raise boost to 10-12lbs. will i need another pump to supply enough fuel?
#141
#143
#146
blown383 tell me that was fun trying to get that sending unit back in the tank. LOL! It took me a 1/2 trying to get that thing back in.
I had to go back to my old sending unit as I jacked up theirs trying to modifiy the y-block. That yellow was a pain removing and putting on my old sending unit. OMG! Now I'm worried if it isn't sealed as tight as theirs will it cause a pressure problem? I got it on there snug but not dead tight as his.
#147
Now the question is where can you get the factory style corrigated clear fuel hose? Seems like that's the only stuff out there that does't get softened by all the ethanol they're putting in gas now.
#148
I used some stuff from Carquest that's fuel line rated for in-tank use. It's special order and sold in 6" sections... Earlier in this thread lists a place that sells that flex hose, but the place only sells them if you buy a pump. He does let you order as many as you want with one pump order though.
dealerships don't even sell that flex hose separate...
#149
-B
#150
Originally Posted by blown383
It wasn't too bad but I had to maneuver and angle that thing for a while before it would seat properly. Even then it was still wasn't seating properly. I have to redo my entire fuel system because the stainless braided line I have was actually Teflon instead of the CPE rubber. So now all of the hose ends and fittings that I bought won't work!!!! Now I have to measure and cut the lines so that the fitting shop can hydraulically crimp the proper fittings on. So there is no chance of leaks.
-B
-B
