Paxton mounting bracket for LT1
Old Aug 24, 2006 | 02:54 PM
formulalt4383's Avatar
Hello, I am new to this board but was hoping someone can point me in the right direction to how I can go about locating a mounting bracket for a SN series Paxton on a LT1 F-body. I bought a TPI sn-93 kit hoping to use the same mounting bracket and slightly modify it but its not going to work. I then ordered one from paradise wheels but they sent me a Corvette LT1 bracket by mistake and then told me thats all they currently have.
If anyone could even has a pic of the bracket it would be very helpful as I could maybe make something up. Thanks for any help in advance
Old Oct 29, 2006 | 12:32 AM
1990iroc-z's Avatar
Formula you by chance wouldnt want to sell tpi 93 mounting bracket would you?
Old Oct 29, 2006 | 02:29 AM
I did trade the TPI mounting bracket for the one I am currently using. However, I did make a template prior to shipping. I could attempt to cut out a bracket using a sheet of aluminum if you are really in a bind.
Also if you need the installation instructions let me know, I scanned every page and have them on computer that I can email you.
Old Oct 29, 2006 | 04:59 AM
pavement pounder's Avatar
Check: http://superchargerhelp.com/ there are some Paxton SN users with the LT1
Old Oct 29, 2006 | 05:07 AM
Thanks, I am actually a member there too. I ended up modifying the LT1 Corvette bracket I had to work on my Formula. So I am pretty much all set on my end.
Old Oct 29, 2006 | 09:00 AM
1990iroc-z's Avatar
Formula, That would be great if you can e mail me the installation instructions. I dont need the bracket as I have one but I think I am missing a pulley on it, and I am missing the crankshaft pulley and drive belt. It would be a HUGE help if I had the installation instructions my email address is chil@speednetllc.com Thanks for the helpC had
Old Oct 29, 2006 | 09:22 AM
Instructions are sent. I also still have a alot of the parts from the mounting kit besides the bracket itself. I have the drivebelt but I am going to try and use that and they are pretty cheap for a replacement at autozone or advance anyway. I do have the idler pulley though and most of the spacers and bolts. I am using the crank pulley on my car as well though. Good luck, I know how hard it is to locate some of the bits and pieces so let me know if I can be of any more help.
John
Old Oct 29, 2006 | 12:25 PM
1990iroc-z's Avatar
Thanks for the instructions, that is a big help, if you want get sell the parts you arent using let me know.
Thanks again Chad
Parts Wanted
Mar 17, 2015 11:24 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Jason Short
Jan 19, 2015 06:34 PM
Cam's maro
Jan 8, 2015 05:01 AM
bman555
Aug 11, 2002 10:56 PM
