Paxton; are the horror stories true?
Old Dec 7, 2003 | 01:35 PM
  #16
Osmosis's Avatar
Where did you access your oil system for the charger?
Old Dec 7, 2003 | 02:28 PM
  #17
Willie's Avatar
The Paxton was self-contained. So was my D1SC. And so is my new F1. No oil lines to deal with!! Is that cool, or what??
Willie
Old Dec 7, 2003 | 02:29 PM
  #18
SharpZ28's Avatar
The "SC" series of ATI chargers are self contained, meaning the oil is in the head unit itself. No tapping of the oil pan is required.
Old Dec 7, 2003 | 02:30 PM
  #19
SharpZ28's Avatar
Sorry, you answered before I could.
Old Dec 7, 2003 | 02:39 PM
  #20
Osmosis's Avatar
So are the D1sc self contained oil systems?
Old Dec 7, 2003 | 02:54 PM
  #21
SharpZ28's Avatar
Yes the D1SC is self contained, the chargers without the designation "SC" are not. I believe ATI has two which still need the engines oil pan for lubrication, these are the P600B and D1.
Old Dec 7, 2003 | 02:55 PM
  #22
Willie's Avatar
The D1SC is self-contained. It uses 6 ounces of ATI's proprietary fluid that should be changed every 6,000 miles. The P1SC is the same. The F1 is also self-contained, although it does not carry the "SC" nomenclature in it's name. It uses 4 ounces.
Willie
Old Dec 7, 2003 | 03:07 PM
  #23
SharpZ28's Avatar
I forgot about the F1. That is a BIG one!
Old Dec 7, 2003 | 03:12 PM
  #24
Willie's Avatar
The F series blowers are considered race only, I believe. The F1 has some unique specs, such as a 5 to 1 step-up ratio. It also has a 70,000 rpm redline. However, it's casing is identical in size as the P1 / D1SC, so it bolted right up to my D1SC bracket. Add a cog system and voila, you've got my setup.
Willie
Old Dec 7, 2003 | 04:34 PM
  #25
Osmosis's Avatar
What is the difference between the p1sc and the d1sc? Price and preformance?
Man, Paxton should have thought about having the novi to bolt up to the brackets on teh sn 2000. Guess thats what set's ATI apart from the rest. Pretty ****ty customer service for paxton!
Thanks for the help Willie!
OZ
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
93 RedBird
Nov 15, 2015 08:24 AM
NewsBot
Sep 16, 2015 10:30 AM
NewsBot
Sep 14, 2015 08:50 AM
