Paging SleeperZ some q's
Old Feb 27, 2004 | 02:46 PM
Pro Stock John's Avatar
Jake, do you know if Jess sent the EDis yet? Thanks for your help.
Also what are you guys paying for C16? I also wondered if Jess would ever take a pic of his fuel system, sounded interesting.
Old Feb 29, 2004 | 06:54 PM
sleeperz28's Avatar
I just spoke with jess, he sent it out middle of last week, so you should see it this week. We pay about 7.30 a gallon or $400 a drum. His fuel system is setup the same way mine is, except he is still using the factory tank for pump gas, where I put an aluminum cell in. Ill have to get some picts of my cell in the car, its unique but not legal at the track. Race gas is through a 5 gallon cell located in the spare tire well on my car. Everything can be switched in the car which is really nice.
Old Mar 1, 2004 | 10:19 AM
Yah,. when I talked to Jess about the dual tank fuel system it sounded very interesting. Does each tank go into a Y block in the back of the car?
Old Mar 1, 2004 | 12:42 PM
sleeperz28's Avatar
yup then a check valve after each pump to keep the fuel in that particular tank
Old Mar 1, 2004 | 03:04 PM
Nice, we need pics someday Jake!
Tell Jess thanks, the EDis just showed up.
Old Mar 1, 2004 | 04:31 PM
Birdie2000's Avatar
Wow, sounds like an awesome setup! Pics and/or details would be much appreciated!
Also... could you put the Y-block before the pump so that you would only have to use 1 pump?
Old Mar 1, 2004 | 11:16 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
you can use a switchable y block.. so you can run one pump, and switch between the 2..
in my case, I am using 2 pumps, so if I had gone the "dual" pump route, I woulda had to have 4 pumps!
Old Mar 1, 2004 | 11:18 PM
Birdie2000's Avatar
Where can I obtain one of these switchable y-blocks? This is really intriguing!
Fatdog2
Sep 16, 2015 11:04 PM
cmsmith
Aug 27, 2015 06:37 PM
97blackformula
Aug 27, 2015 06:02 PM
WPHIG2
Aug 27, 2015 06:37 AM
cmsmith
Aug 20, 2015 07:57 PM
