Paging SleeperZ some q's
Jake, do you know if Jess sent the EDis yet? Thanks for your help.
Also what are you guys paying for C16? I also wondered if Jess would ever take a pic of his fuel system, sounded interesting. |
I just spoke with jess, he sent it out middle of last week, so you should see it this week. We pay about 7.30 a gallon or $400 a drum. His fuel system is setup the same way mine is, except he is still using the factory tank for pump gas, where I put an aluminum cell in. Ill have to get some picts of my cell in the car, its unique but not legal at the track. Race gas is through a 5 gallon cell located in the spare tire well on my car. Everything can be switched in the car which is really nice.
Yah,. when I talked to Jess about the dual tank fuel system it sounded very interesting. Does each tank go into a Y block in the back of the car?
yup then a check valve after each pump to keep the fuel in that particular tank
Nice, we need pics someday Jake!
Tell Jess thanks, the EDis just showed up. |
Wow, sounds like an awesome setup! Pics and/or details would be much appreciated!
Also... could you put the Y-block before the pump so that you would only have to use 1 pump? |
you can use a switchable y block.. so you can run one pump, and switch between the 2..
in my case, I am using 2 pumps, so if I had gone the "dual" pump route, I woulda had to have 4 pumps! |
Where can I obtain one of these switchable y-blocks? This is really intriguing!
