Paging: Rich Krause
Old Mar 14, 2005 | 06:11 PM
96vortechSS's Avatar
Paging: Rich Krause
What pulley sizes are you running on your F1? Or I guess I should say what pulley sizes should I use with the 12 rib pulleys to make 14-18 lbs/boost?
Old Mar 14, 2005 | 06:28 PM
rskrause's Avatar
Moderator
Re: Paging: Rich Krause
Well, there is a big difference between 14 and 18psi! Mine is 17-18psi and I don't recall the exact pulley sizes and they are not where I can easily measure them at this moment, but it is pullied to max out the blower at 6,500rpm. So, whatever the exact sizes are, the ratio is ~1.5:1. There are only a few different size 12-rib belts available, I'd recommend calling Prochrager and asking them what pulley/belt combos are available to spin the blower to the desired rpm.
Rich
Old Mar 14, 2005 | 08:36 PM
Lonnie Pavtis's Avatar
F-1 70,000rpm max
5:1 internal ratio
7.65" lower pulley
peak rpm 6500
blower pulley = 3.55"
Rich, could you confirm, (this would be a 2.15:1 ratio) you should be seeing a lot more boost with those pulleys. I would guess a 3.55" would give closer to 20# on your car.
Old Mar 14, 2005 | 09:35 PM
rskrause's Avatar
Moderator
Originally Posted by Lonnie Pavtis
F-1 70,000rpm max
5:1 internal ratio
7.65" lower pulley
peak rpm 6500
Lonnie: math isn't my strong point! However, I do see ~22psi with a "bare" air inlet. Even though I had my buddy fabricate a rigid inlet pipe, I still lose 4-5psi with it. Using the POS inlet Procharger provided, it wouldn't make more than 15psi, barely more than the S-trim. As far as the math goes, I was using 50,000rpm. I guess I had a brain fart deja vu back to S-trim days. My huge dyno numbers were with the MAF removed and no inlet. If I were seriously racing the car, I would remove the MAF permanently and do something else with the inlet.
This proves two things: I suck at math and the centrifugal SC do NOT like inlet restrictions.
Rich
drt
Sep 27, 2015 04:39 PM
greenzee28
Sep 25, 2015 04:29 PM
HAWG
Sep 25, 2015 11:41 AM
damnyankee36
Sep 9, 2015 07:06 PM
