Oil Cap leaking oil - Need special Oil cap with filler neck
Old Aug 11, 2011 | 10:19 PM
No_Secrets's Avatar
Guys,
Can anyone direct me to a part # and or company that makes an LT1 oil cap with a neck filler? I have a supercharged motor and it is making so much pressure it is leaking from the oil cap.
Thanks in advance!
Jeff
Old Aug 12, 2011 | 01:27 AM
97WS6SCharged's Avatar
Re: Oil Cap leaking oil - Need special Oil cap with filler neck
You'll need to put check valves in the air hoses from the TB to the valve cover and the PCV system.
K&N also makes a filter for the valve cover. Should be PN# 62-1495
Old Aug 12, 2011 | 07:15 AM
No_Secrets's Avatar
Thanks Chris I found something similar to what you are suggesting.
http://musclemotors.com/valve-cover-...02-p-1277.html
This at least has a neck to allow the oil to run up on WOT. The problem is I believe under WOT it will still find its way out through the breather. I want something similar to this design but with an oil cap design (screwing into the neck tube).
Anyone else have any ideas or a part number of something that will work??
Old Aug 12, 2011 | 07:53 AM
That looks like the same filter it just comes with a nifty looking base. How do you have your PVC & fresh air supplies hooked up? If you didn't install check valves then you will pressurize the crank case under boost. I blew the dip stick out of my motor doing that one time.
Old Aug 12, 2011 | 07:59 AM
No_Secrets's Avatar
Yes that nifty looking base, I just wish it was taller if you know what I mean!
Not sure how the PCV is set up...will look into this. LOL...hell if you blew the dip stick out I know for sure I will need to address this issue. For now I am driving around like Granny.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
captcorvette
Mar 7, 2015 12:37 PM
The Seer
Nov 24, 2014 07:59 AM
Jul 4, 2005 05:00 PM
