O2 sensor mounting location
Old May 22, 2006 | 11:33 AM
davepl's Avatar
Due to clearance issues, I had to move my O2 sensors back about 12" from the header collector.
I know they like it more forward if possible, but they seem to do ok way back at the tailpipe when you're on the dyno.
So is the preferred forward mounting an emissions thing (getting the sensor to warm up sooner to go into closed loop) or is it a lag issue (since it takes a few microseconds longer to move 12", maybe the ECU can't react as fast)?
Either way, will 12" make a difference?
Old May 22, 2006 | 11:36 AM
Sparkz28ss's Avatar
Re: O2 sensor mounting location
I doubt it..
I just dont like to have mine after the collector ...
just so if I have a leak my car wont run like assbag
Old May 22, 2006 | 11:37 AM
davepl's Avatar
How is assbaggishness prevented by being in the collector? Isn't a leak a leak?
Old May 22, 2006 | 12:07 PM
davepl's Avatar
Never mind, I get it now... a collector leak, which is common, won't necessarily affect the sensor if the sensor is upstream of the collector, but if its downstream, it will for sure.
Old May 22, 2006 | 02:19 PM
Sparkz28ss's Avatar
exactly ......
HectorM52
Jul 30, 2017 11:46 AM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
Jazsun
Dec 29, 2014 12:14 PM
Timberwolf
Jul 20, 2002 08:45 AM
