NGK TR6 spark plug gap with ATI procharger
Old Nov 23, 2003 | 01:05 PM
OrionSPL's Avatar
I am in the process of putting my motor back in and bolting on my ATI Pro-Charger D1-SC. Anyone know what gap I should use with the NGK TR6s? I will be running 12lbs of boost on the street with 94 and 14lbs at the track with 110. I also have an MSD 6AL, other mods listed in profile. Thanks!
Old Nov 23, 2003 | 02:54 PM
Sparkz28's Avatar
.035
thats what I do...
Old Nov 23, 2003 | 03:33 PM
My ambitionz's Avatar
hey orion, I'll be running a very similar setup to you: ls6 stage two heads, and a d1SC as well. I got a ten pound pulley to run on it. My question to you is. Are you gonna run 14 psi with stock CR/bottom end?
Old Nov 23, 2003 | 03:35 PM
EDIT: just read your sig... Never mind. Although what CR are you running?
Old Nov 23, 2003 | 05:33 PM
OrionSPL's Avatar
I am running 9.1:1 compression ratio.
Old Nov 23, 2003 | 09:03 PM
IDOXLR8's Avatar
I usually recommend gapping them at .032
racecarz28
Mar 30, 2015 09:55 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Jazsun
Dec 29, 2014 12:14 PM
SC97TA
Sep 15, 2002 01:10 AM
