newbie question
Old Mar 25, 2006 | 05:52 PM
spcearle's Avatar
newbie question
....i'm very unfamilier with turbo's and chargers and was just wondering if it was possible or fesable to use one on a 11+ compression 383 lt1 ....and if so which would be better or would work good for a street car and what gains i'd be looking at
Old Mar 25, 2006 | 09:01 PM
dgZ's Avatar
dgZ
Re: newbie question
Its possible to run boost on any engine, if it holds up for long is a different story. Generally, you will want a lower compression engine than 11+:1 when using forced induction. Even the lt1's stock 10.5:1 compression is high for boost, but some get away with boosting it 4-6 psi. Id reccommend not boosting an engine with a 11+:1 compression.
Old Mar 29, 2006 | 09:52 AM
97WS6SCharged's Avatar
Re: newbie question
It should work fine if you don't mind running C16 all the time.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Z28countrymama
Jan 22, 2015 02:50 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
95dzz28
Jan 12, 2015 05:58 PM
Brad 97z
Aug 10, 2002 09:58 AM
