New numbers D1SC cogged
Old May 5, 2004 | 01:59 PM
  #16
Lisa33's Avatar
Its turning, i was waiting at the finishline after the run. But if i remember correct the tensioner is fixed not like the stock ones widht springs....
Old May 18, 2004 | 07:44 AM
  #17
TonyJ's Avatar
Originally posted by rskrause
Good luck with the cog. FWIW I advise against a cog setup for street use...
Rich Krause
Well Rich, it looks like you are right. We dropped the engine last night to put on Cometic head gaskets and decided to check the crank bolt. It turns out the cog drive setup applies so much to the crank it had partially worked the bolt out enough to screw up my crank/damper keyways... My builder thinks that it's just too much on the end of the crank and will eventually bust the end off... Anyway, in the interest of keeping the engine in the car, I'm going back to the 12-rib setup. (thankfully I didn't sell it- had lots of offers/begging...) Anyway, I'm going to hate to lose the extra boost, but it's probably worth it. What tensioner are you using and where did you get it?
Thanks, TJ
Old May 18, 2004 | 08:56 AM
  #18
IDOXLR8's Avatar
Thanks, TJ
I would highly recommend going with an SD concepts spring loaded tensioner.
Old May 19, 2004 | 06:52 PM
  #19
TonyJ's Avatar
Turns out the fluid dampr broke clean through at the keyway. I've got an ATI on order that we'll double-key and I'm going to get one of the new big block sized hubs that ATI is making for S/C applications. The have to make the hub and it takes three weeks. I'm going back to the 12-rib setup and will decide what to do based on how much hp I lose. I may go back with the cogs after I upgrade the hub. We'll see...
D1SC383LT4
Jan 1, 2016 01:56 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
1LEThumper
Jul 14, 2003 12:45 PM
