need help with turbo headers
Old Jun 14, 2004 | 12:26 AM
blownxtreme's Avatar
well i ve looked around and have not found much, what matterial are you guys using to make your turbo headers ? everything i find is either 18 or 16 guage. For a street driven vechile would you use mild or stainless steel, i keep hearing stainless steel is to britle for use on turbo headers. thanks again for all your help. links to any sites that sell heavier bends would be great too.
Old Jun 14, 2004 | 04:44 AM
SMOKNZ's Avatar
I used 16 gauge mild steel. http://www.schoenfeldheaders.com/U%20&J%20Bends.htm
I bought their "odd bends" for $89, and was able to make 2 complete sets of headers and have tubing left over.
Old Jun 14, 2004 | 03:33 PM
96TurboTA's Avatar
I got the same thing as Bill. It comes with a ton of bends. Well worth it. Usually you can find the Schoenfeld stuff from companies that sell Circle track parts.
Old Jun 14, 2004 | 04:47 PM
texlurch's Avatar
Mild steel here also, then coated with a 2000 deg ceramic coating.
Upside down S-10 swap headers, no less!!
Old Jun 14, 2004 | 07:56 PM
SMOKNZ's Avatar
I will be costing mine as well with 2000 deg aluminum look ceramic coat. Got it from colombia coatings, as well as most of my powdercoating stuff. I will be running the headers uncoated for a few heat cycles, then removing them and making sure there are no leaks. I'll also be retourqing the heads as well. I hope to prevent any coolant leaks from the heads this time!
Bill
Old Jun 15, 2004 | 02:15 AM
do you guys know of any places that sell 14 guage header tubbing ? i do plan to have them ceramic coated.
LeftoverChinese
Jan 14, 2024 03:03 PM
Highlander
Jan 12, 2020 02:13 PM
dylan1303
May 22, 2015 12:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
