Need help picking a spark plug for my AFR 180 heads...
Old May 16, 2007 | 02:25 PM
CALL911's Avatar
Anyone have any suggestions? I have AFR 180 heads (needing a gasketed plug). I have some form of discontinued iridium plugs in it now, and am in need of replacing them. Autolite 103's were suggested, but they are not a gasketed plug, and thats what I need. BTW, am running a D1SC at 15-16#'s of boost on my 383 in my sig.
Old May 16, 2007 | 02:39 PM
CALL911's Avatar
Basically what plug is equivilant to an Autolite 103 that has a gasketed seal for an AFR head?
Old May 16, 2007 | 09:11 PM
CJ's Avatar
CJ
AC Delco FR1LS
Old May 16, 2007 | 11:01 PM
CALL911's Avatar
I am wanting to stick with an Autolite plug here. I've got it narrowed down to either an Autolite 3922, or a 3923, but I'm not sure which one is the same heat range as an Autolite 103.
Does anyone know? Or know which I should run based on the approximate boost level (15#'s or so) I am at??
Old May 17, 2007 | 06:19 AM
Schurters LT1's Avatar
put the 103 in you will be fine..
Old May 17, 2007 | 09:49 AM
Jeff 96 SS's Avatar
Dont use the 103 I recomend using an NGK race plug I beleive the
739-R5672A8 is the same heat range as the 103 or you could go one colder and use the A9
Old May 17, 2007 | 10:47 AM
Sean94Z's Avatar
I second this, a lot the big HP turbo guys run these plugs and swear by them.
Old May 17, 2007 | 10:56 AM
CALL911's Avatar
Guys, I can't run the 103 because I need a gasketed plug for my AFR heads. The 103 is the ideal heat range, but I need to go with either the Autolite 3922, or the 3923.
Between these two plugs, which should I run?
BTW, I don't want to run NGK's.
Old May 17, 2007 | 10:58 AM
Sean94Z's Avatar
I ran the 3923 before I switched to the NGK R5672A8 and picked up over 20HP at the wheels.
Old May 17, 2007 | 11:57 AM
joe-96z1le's Avatar
The 3922s are colder than the 3923s. Try the colder plug and see how it does. If it fouls, go one step warmer. However, from what I've seen, you want the NGKs...same price as regular plugs...R5671A-8 even colder, prolly not req'd. R5671A-7 cold. These are flat seat plugs and are properly designed to disperse and dissipate heat in high performance engines.
Just checked. The 71's are non-projected. The 72's are projected nose. Otherwise, they're the same plug.
Old May 17, 2007 | 04:21 PM
Lisa33's Avatar
A good thread http://web.camaross.com/forums/showthread.php?t=431689
We run NGKs 7 heatrange
Old May 17, 2007 | 08:59 PM
BMAN'S SCZ's Avatar
I run the 3922's with 10#. No problems, but will try the NGK R5671A-8 next. Good Luck...........John
Old May 17, 2007 | 10:55 PM
xxsaint69x's Avatar
Originally Posted by CJ
AC Delco FR1LS
thats whats in mine
Old May 18, 2007 | 07:47 AM
CALL911's Avatar
I just picked up a set of the 3922's. Thanks for the help everyone.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Dark Zeiro
Mar 11, 2015 07:15 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Jazsun
Dec 29, 2014 12:14 PM
