Need advice: To FAST or not to FAST
Im having a dilema. Im trying to decide if the FAST setup is worth it. My current engine harness is showing its age and giving me problems. At the same time I would like to get rid of the opti. These are my two main concerns that I want to fix. If I could fix these two problems i.e. keep my opti up and running and get rid of my gremlins I would be happy with the setup. I dont think my cam requires the kind of rpm that would exceed the capabilites of the stock pcm ( 224/236 .606/.628) so thats not a consideration in deciding. I have heard that there are some features that the stock pcm has that are not available with the FAST, what are they?? From the website, it looks like they have everything covered. I would like to keep the car streetable. Anyone using FAST on a daily driver?? THe big question is can I get rid of the opti, run a conventional distibutor and still have sequential fuel injection?? Would BS3 be a better alternative?? Thanks for any info
From: I reached back like a pimp and smacked that LS1....
I personally prefer the BS3 engine managment and it is what I run on my own car.
Running in speed density with a wideband o2 (as you would with BS3) is much safer than running the stock ecm with a maxed maf sensor as it's essentially running blind.
I also have the stock PCM wired in to control everything else.
Is there any difference in tuning in Speed Density vs tuning with the MAF i.e. as far as diffuculty
I prefer Electromotive to FAST and use it on my race car. That said, the Camaro works fine with the stock PCM and an impedance converter. What do you hope to gain with the FAST (or any aftermarket ECU)?
Rich
Rich
