my t6 pt88 progress picz
Old Oct 19, 2005 | 09:03 AM
  #16
z28draco's Avatar
Re: my t6 pt88 progress picz
I have a fabricator at Roush Racing port matching my intake while I'm doing the wiring. It is a Victor "E" EFI...with a 90 degree elbow that I fabricated for a Nick Williams 90mm TB I had from an LS1 car.
For under hood temps I was really considering a jet hot type coating but I dont know if i want to do that because I love the way stainless looks welded... see my delema...lol
Old Oct 22, 2005 | 08:09 PM
  #17
GhostZ's Avatar
Deeeeeeeeeeeeeeeeelicious!
Old Oct 23, 2005 | 11:53 AM
  #18
Ws6cott's Avatar
Very nice...
I love the gauge cluster...I have been wanting to do mine like that for awhile...looks much cleaner and more functional that the stock cluster.
Scott
www.ccrdetroit.com
Old Oct 24, 2005 | 02:05 AM
  #19
Geoff Chadwick's Avatar
Scott- just shot through your website and was curious to see if there was any more progress on the H3 setup. Noting that power was the H3's weakness I'd love to hear more about it.
(not to hijack the thread...)
Old Oct 24, 2005 | 03:22 PM
  #20
BADST95's Avatar
Smile Re: my t6 pt88 progress picz
At the risk of being the "bad guy"... I have a few questions.
1) Are you using an opti-spark? If so, I don't know how long it will last due to the heat that will be generated by the turbo as it is close to the opti.
2) How maintenance friendly is that set up? Regular maintenance seems as if it might be a little tough. How is the spark plug access? Especially on the passenger side?
3) Are you using an intercooler? If so, how do you plan on routing the tubing?
Old Oct 24, 2005 | 05:11 PM
  #21
z28draco's Avatar
don't worry...people have a right to ask questions...
1) opti is only used for cam position and im using a coil per cylinder setup...
2) maintenence will be a sinch...all header tubes are above the plugs...i put um all in from the bottom with ease after installing the headers...the coil packs will be mounted on the frame rails so no problems with wires either...
3) anyone who doesn't use some form of intercooling in a TURBO setup shouldn't be running a turbo...i am waiting on a couple liquid/air intercooler cores from honeywell/garrett right now...i will post pics of the ic setup when finished...
-nick
Old Oct 28, 2005 | 03:16 PM
  #22
DiabloGT's Avatar
Originally Posted by z28draco
I used a Mojave summit 2800 btu 260 cfm heater...ill get some more pics up tonight as im working right now....
Here are some pics before i did the tubes to the turbo or the DP and yes it is a 4" DP
http://motownmuscle.com/forums/attac...achmentid=5234
http://motownmuscle.com/forums/attac...achmentid=5233
http://motownmuscle.com/forums/attac...achmentid=5232
is that custom made valve covers? and i thought they had to be centerbolt? isnt yours lt1/lt4? will these ones fit:
http://store.summitracing.com/defaul...=egnsearch.asp
if i get my alternator relocated?
thanks
Old Oct 28, 2005 | 07:57 PM
  #23
96TurboTA's Avatar
thanks
He may be using adapter plates.
Old Oct 29, 2005 | 05:53 AM
  #24
z28draco's Avatar
or i may have converted some sbc heads to reverse coolant flow
Old Oct 29, 2005 | 07:36 AM
  #25
Loadre's Avatar
Is the steering shaft already in? Looks like there's no way in hell it would fit just by the looks of it.
Old Oct 29, 2005 | 05:27 PM
  #26
z28draco's Avatar
its in
Quickss96
Jan 29, 2016 05:56 PM
marlar98
Sep 19, 2015 07:53 AM
NewsBot
Sep 14, 2015 09:20 AM
NewsBot
Aug 21, 2015 07:20 PM
NewsBot
Aug 17, 2015 11:40 AM
