Is my car running too cold
Old Jun 16, 2003 | 05:41 PM
Camaro_SS/R's Avatar
I have the 160 thermo and the Meizeire HD water pump. The fan are setup to come on at 176 and 181.
With this setting, the car will run at below 1/8 mark about 170 even with street driving. On a hot day 90 F outside, the car will still be at 170 on the highway, then will go up near the 1/4 mark about 180 with street driving.
What I have notice is that it ran better street driving when it was hotter. The on off throttle is smoother and the cruising is smoother!?
Should I set the fan to come on at a higher temp maybe 180-190.
Anyone else notice something similiar and know why. I always thought colder is better.
TIA
Old Jun 17, 2003 | 08:18 AM
DJ:BOTA's Avatar
From: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
Wow, I wish I had your problem. Sorry, I don't know.
Old Jun 17, 2003 | 08:53 AM
kmook's Avatar
Advanced Tech Moderator
Id rather keep it colder.
I had it even more extreme than you. I had a 160 thermo, yadayada... and the fans hard wired to always be on. Even on the hotest days in S FL i would never get but a smidge above the first mark
Old Jun 17, 2003 | 01:22 PM
DJ:BOTA - it's nice that it is cold, just make me feel safer for the engine.
Ken - I quess you wouldn't recommend making it run hotter
On a very hot day with street driving, it is below the first mark and seem to like it more there. On the other 90% of the time, it is below half of the first mark. Maybe it is smoother because it is slower. I really need to buy Atap, so I can program the VE table.
thanks
--Hugh
Old Jun 17, 2003 | 02:17 PM
kmook's Avatar
Im not saying its better, im just giving my personal preferance.
Old Jun 17, 2003 | 03:19 PM
10secz's Avatar
The following may look like a contradiction, but is based on *decades* of reading about internal combustion.
1) Hotter *engines* make more power. The heat of combustion is what makes the thing go. I've read about small experimental engines based on structural ceramics that don't need any cooling system.
2) Colder *air* is denser, meaning that there is more oxygen per unit volume available for combustion. Hot air is why your car feels sluggish on hot days, and cold air is why it flies in the early spring. I'm told colder inlet air helps supress detonation, but it seems unlikely to me that a 40* difference (50 vs 90, say) would have much of an effect on combustion temperatures way over 1000*.
So you want a fully warmed up engine breathing chilled air for max power.
I think the diffenence between halfway to the first tic mark on the gauge and all the way to the first tic mark is too small to make a noticable difference in performance, except for the hot air effect. If your IAT could be held constant, I really doubt the dyno would show much difference between 1/8 of full scale and 1/4 of full scale. It would be interesting to plot IAT vs engine temp.
I wonder if you have a step in some PCM table that happens around 180*. This could cause a noticable performance difference.
Old Jun 17, 2003 | 04:12 PM
This is exactly what I was thinking of too. I have been looking through the Edit to figure this out, but couldn't find the table. And was going to make the car run at 180-185 since that should not be much of a difference from 170-175 in terms of what the engine is seeing and doing.
thanks
--Hugh
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
