Motors rebuilt, have a few questions..
Old Jun 26, 2004 | 10:51 AM
DJ:BOTA's Avatar
From: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
Everything is running pretty well, 355 with some forged parts, stock injectors, P1SC, 8.5:1 comp.
I'm having surging issues with the idle. It's going from a stall to about 1300 rpm. Up and down. It only happens when the car is warm. Someone told me to have the crank sensor reset at my chevy dealer. Apparently there is no sensor reprogram on the tech2 tool for a '95. What can I look into? The cam is still stock as well.
My only other question is about break in. How many miles should I put on my car before I can hammer it? My guy told me not to really get into the boost until 500 miles or so. Is that good?
Old Jun 26, 2004 | 09:37 PM
5.0THIS's Avatar
500 miles should suffice. It really depends on how tight you had all your tolerances set up, and how your clearances are, bearings, rings, and so forth..... just vary your rpms, and try to keep the engine under varying loads, but never too heavy at first
Old Jun 26, 2004 | 09:59 PM
TonyJ's Avatar
I don't think '95s have the crank sensor. Maybe I'm just senile...
Old Jun 26, 2004 | 11:07 PM
SMOKNZ's Avatar
They don't. Only the OBD2 LT1 cars have them (96-97)
Old Jun 27, 2004 | 03:01 AM
97WS6SCharged's Avatar
I've got the same surging problem on mine. It seems like the car wants to go slightly lean at idle when it's hot and then the computer over compensates and nearly stalls the car out (some times it actually does). I just haven't had a chance to fix it yet, but you may be having the same problem.
Old Jun 27, 2004 | 09:12 AM
DJ:BOTA's Avatar
What about sending the computer out? Seems like we might have a program problem.
Old Jun 27, 2004 | 09:41 AM
TonyJ's Avatar
Sounds like an IAC issue or like you've got a vacuum leak to me. Have you tried cleaning the TB and IAC? No codes?
Old Jun 27, 2004 | 10:02 AM
DJ:BOTA's Avatar
The only code the car is throwing is for the air pump which fell off.
Old Jun 28, 2004 | 12:56 PM
MEAN LT1's Avatar
I hear what your saying. Mine did it as well but only di so when after sitting say at a stop light for like 5 minutes or so. Im sure it has to be something with the iac. have you replaced that yet?.
Old Jun 28, 2004 | 08:16 PM
DJ:BOTA's Avatar
No, I haven't replaced it yet. I think that'll be the 1st step.
Collector Car
Jan 5, 2015 10:58 AM
Jazsun
Dec 29, 2014 12:14 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
