Modding the fuel rail
Old Oct 1, 2004 | 08:12 AM
  #16
MrDude_1's Avatar
Re: Modding the fuel rail
Originally Posted by mongse_1
I did just like Tex did. TIG'd on -8AN fittings to the back and top front of the rails and mounted a Weldon regulator on top of the intake. Here's a tip...braided line and fittings are stupid expensive. I've got about $2200 in the fuel system and that's using the company discount on parts.
yea. braided is expensive.... outdated too.
looks cool. and if you want the flash and a strong hose, go for it.
but theres a whole selection of various approved lines.. some are even more abrasion resistant, and hold more pressure...and they're cheaper. only downside is they arnt shiny. personally i like the black "is that stock?" look... most of the time, braided line looks out of place IMO... but like i said, its a cosmetic opinion thing.
if money or performance is the primary concern, you have several other sanctioning body approved, cheaper options.
Old Oct 1, 2004 | 01:31 PM
  #17
speedmiser's Avatar
I used mostly black Aeroquip hose and pushlock fittings. Cost of the hose wasnt to bad, but the cost of the fittings is what really ran up the price. I suppose I did go a little overkill with the fuel system routing though - I tapped the front and back of both rails for -6 feed. -6 fittings are also welding into the center top of the each rail, which return to an Aeromotive regulator (like Texlurch has), then returns to the tank.
Old Oct 1, 2004 | 01:55 PM
  #18
Birdie2000's Avatar
Which lines are you referring to MrDude_1?
Old Oct 1, 2004 | 03:03 PM
  #19
MEAN LT1's Avatar
I want to know a well.
Old Oct 1, 2004 | 03:23 PM
  #20
MrDude_1's Avatar
its hose very similar to the black earls hose sold in summit... let me see if i can dig up the name of the stuff... i think it has a kevlar braid on it, not sure on that...
Old Oct 3, 2004 | 09:35 PM
  #21
Roadie's Avatar
I've always been partial to the Russell Twist-lok stuff. Still interested in what you're talking about. Got a product name?
Old Oct 4, 2004 | 10:10 AM
  #22
MEAN LT1's Avatar
Found the name of it yet?.
Old Oct 4, 2004 | 02:25 PM
  #23
MrDude_1's Avatar
yea, i just got a email back from the guy i got my hose from... he said its called StartLite... i donno who makes it though.
in anycase he said it has kevlar on the outside so its really abrasion resistant. i emailed him back, asking who made it, but hes really slow to respond... (hence the wait)
Old Oct 4, 2004 | 10:19 PM
  #24
EddieP's Avatar
StartLite hose is made by Aeroquip ... supposed to be ~50% lighter than stainless steel braided hose.
Old Oct 4, 2004 | 11:52 PM
  #25
lt1camaroman93's Avatar
I ran a -10 line to a Y then 2 -8 lines to the back of the fuel rails. Then from the front of the rails it is 2 -8 lines to the regulator, then a -6 line back to the tank for a return. I wish i wouldn't have went with braided as it is $20+ for every fitting that isn't straight, which is the majority of my fittings.
Old Oct 5, 2004 | 04:51 PM
  #26
arnie's Avatar
What did you figure was your alternative? In case you were considering the lighter Startlite hose instead, it would have been twice as expensive per foot, and use the same $$ fittings, unless you would choose to have hose supplier install the lightweight crimped fittings designed especially for the Startlite hose.
Old Oct 5, 2004 | 10:52 PM
  #27
I can't remember the name of the company, but it was like this pushlock stuff.. It was a little chaper, but not by to much. It just sucks knowing i spent around $1500 for a fuel system.
ad356
Apr 16, 2015 05:38 PM
dfarr67
Apr 10, 2015 07:44 PM
4586
Feb 13, 2015 09:16 AM
birdblack
Dec 30, 2014 06:59 PM
Jul 4, 2005 05:00 PM
