Metal in oil
Old Aug 3, 2009 | 12:27 PM
formulaboy_95's Avatar
Metal in oil
I drained the oil, and I have very fine metal in the oil. It looks like it is aluminum, and a magnet could not pick it up. Oil does not have more than 30 miles. What is the likely culprit? Engine idles okay, pcm log looks fine, no knock. Pulled a few plugs and they looked perfect. Car has a stock bottom end LT1. Am I completely screwed?
Old Aug 3, 2009 | 12:52 PM
jsetzer's Avatar
How much? How does the oil pressure look?
7lbs is a good bit on a stock bottom end - not if but when.
Old Aug 3, 2009 | 01:44 PM
The oil pressure goes down to 10psi at idle after 20-30 mins. It used to be around 20 at idle. I recently added a restrictor on the turbo due to burning oil during boost. Now I only see some smoke after getting out of boost. Car is running 10.8 AFR during boost. The metal is really fine.
Old Aug 3, 2009 | 06:08 PM
Quick Impala's Avatar
Sounds like the bearings have given up the ghost....
Old Aug 4, 2009 | 09:49 AM
paxtonLT1's Avatar
do you have blow by? i had a lot of fine metal from my piston ringland coming apart and low oil psi. goodluck man.
Old Aug 4, 2009 | 10:36 AM
matLT1's Avatar
Sounds like bearings to me.
Old Aug 4, 2009 | 04:50 PM
No blowby that I can tell... Car seems to run fine. Whatever it is, the magnet did not pick it up. I still have to cut the filter open. I was going replace the pan & gasket, but got discouraged after looking at that. I know it is on borrowed time anyway, but it was running real strong before the turbo. I am working on picking up an extra block to build up on the side. I will know more once I get the pan dropped.
Old Aug 4, 2009 | 05:14 PM
PoorMan's Avatar
Run 20w-50 in it now man. May buy u some time. I would also get one of those magnets that attach to the side of the oil filter just for any ferrous stuff in there.
R@mpage
Apr 20, 2015 10:02 AM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
