Maxing out Maf sensor
Old Jan 26, 2006 | 03:12 PM
  #31
maximumvelocity's Avatar
Re: Maxing out Maf sensor
I believe you can get tunercat for obd2 lt1s for approximatly $400. and I think it does everything that lt1 edit does.
Old Jan 26, 2006 | 10:59 PM
  #32
96camaroSS's Avatar
Sorry if I seem to be hijacking your post, but this thread has got me thinking. I was previously using the Maf Massager to stave off the dreaded high Maf fault. But after purchasing LT1 Edit I pulled it thinking by disabling the fault code I was ok. But can anyone with rock solid knowledge on the subject tell me if I've made a mistake here. Does the Maf still max out and cause the fuel to be cut in half on OBDII cars even with the fault code disabled?
Old Jan 27, 2006 | 10:24 AM
  #33
I believe your question is directly related to this thread. I'm curious myself to the answer to that question, but I think we may be looking at an unmarked (unexplored) territory because I've seen this question asked before with no answer.
Old Jan 27, 2006 | 02:44 PM
  #34
mzgp5x's Avatar
I've read comments by people who claim the injector pulse width is cut by half on an OBD2 system when the MAF threshold is exceeded. I have no physical data to support this. Most of what I have learned on obd2 programming is from L J and Christian M. L J's document helped me. Possibly I can experiment since now I have a wideband o2 to test with.
andrewcapps82
May 19, 2015 10:11 PM
Dzmaro
May 7, 2015 09:33 AM
3TAS4ME
Apr 15, 2015 02:24 PM
pete53
Dec 9, 2014 07:31 AM
