Max lift for beehives?
Re: Max lift for beehives?
Originally Posted by blackztpi
most beehives are rated for .600 max but you wont have a problem going .006 over that
Will,
We'll, I guess the rated max lift isn't everything then....
Nice job on the twin turbo, did you build that yourself?
How in the heck do you change the plugs? It seems really tight in there.
I like the way you did the fuel pumps and tank, if one of the pumps goes bad, you can remove it without taking off the tank again.
How has the twin turbo worked out, would you do it again or just a single turbo? How much power does it put out?
Originally Posted by EDS Z28
Will,
Wow, lot of misleading information here on the beehives.
.600" lift is not a problem on these springs.
If you are breaking beehives (even the 26120's) then something is wrong with the setup.
FWIW I've run hundreds of sets of beehives with high lift and never had any of these problems, even with "running a cam with a very aggressive ramp angle"
Bret
Bret
If they are set at the proper installed hieght then thats half the battle. I beleived the desired hight is 1.800" May cam a over that spec and never had a issue, bret set the head up and is completely right.
