Max HP on optispark (OEM, MSD or other)
Old Jun 6, 2007 | 09:14 AM
  #61
Kelly.'s Avatar
Originally Posted by Boosted_Z28
I've researched this quite a bit myself and finally opted for an LS-1 BS-3 system to run on my LT-1. I chose this for several reasons, but will be able to run in the sequential mode and use a coil-on-plug system as well. I'm using an MSD dist stub that generates a cam sync signal and BS-3's 24x crank sensor. I also chose to replace the stock LT-1 intake with a single plane, 90* elbow and an Accu-Fab 90mm throttle body. I'm hoping this all works out the way I want it to...should be interesting. Keep us posted on your progress, good luck.
i didnt want to be forced to switch to a ls1 ignition, and therefore have to pay $500 more for the ls1 bs3 box.
do you have any pics of you intake? im trying to find one like that. it would make my placement of a dual sync dizzy.
Old Jun 6, 2007 | 09:17 AM
  #62
Kelly.'s Avatar
Originally Posted by whonxt?
I spin my motor to 7k, but I have an AFR Hydra rev kit. If you dont have one, I would rec. it! By the way, I have a stock opti and it works well
my current #'s are not as high as you plan, but they are 630/660 at the tires.
you should come down to the springs sometime,
sounds like ypu got a quick car, im sure there are some people here that may want to check the car out/ race ya
Old Jun 6, 2007 | 02:06 PM
  #63
Sean94Z's Avatar
What cap would you use on the dual sync distributor to fit under the cowl area on the LT1 setup?
I've got a friend who has drilled around 15 LT1 intakes to fit the rear mount distributor and I am considering ditching the OPTI and going for the MSD or Accel Dual Sync to hook up to my DFI..
Thanks,
Sean
Old Jun 6, 2007 | 02:10 PM
  #64
Kelly.'s Avatar
http://www.msdignition.com/dist_14.htm
i think i saw one with a shorter cap, but i cant seem to find it via google.
there was a guy on here that has done it, but again i cant seem to it.
im interested getting my IM drilled for a dizzy, you have a pm
Old Jun 6, 2007 | 02:58 PM
  #65
Rodrigues's Avatar
Heres a pic of John Meaney's 24T wheel and 7.4 Cam trigger
Old Jun 6, 2007 | 07:19 PM
  #66
Boosted_Z28's Avatar
Here is a picture of some of my set-up...sort of mocked up so you can get an idea.
Old Jun 7, 2007 | 10:27 AM
  #67
Rodrigues's Avatar
If thats the MSD trigger it won't work.
Old Jun 7, 2007 | 11:16 AM
  #68
Kelly.'s Avatar
that is the intake i wanna use.
which IM is it?
it will allow for easier fitment of a dual sync dizzy, and it will let me go to a bigger, single butterfly throttlebody.
Old Jun 7, 2007 | 11:41 AM
  #69
NJLT1SS's Avatar
Is it the same John Meaney who created DFI, and Big Stuff 3? Do you have any details about his motor? That intake is pretty tall
Nick
Old Jun 7, 2007 | 12:40 PM
  #70
92LT1RS's Avatar
wish I was still in Colorado Springs, I'd come out and check out some of y'alls cars.
Boosted Z28, that looks like it will make for a fun ride
Old Jun 7, 2007 | 03:09 PM
  #71
Kelly.'s Avatar
it isnt that great, my house is at 6250 ft altitude
Old Jun 7, 2007 | 04:09 PM
  #72
92LT1RS's Avatar
thats ok, mine was at 7280
Old Jun 7, 2007 | 10:01 PM
  #73
What's the problem with the MSD cam sensor?
Old Jun 7, 2007 | 10:05 PM
  #74
which IM is it?
Kelly - It is an Edelbrock Victor E manifold
Old Jun 10, 2007 | 11:37 PM
  #75
Rodrigues's Avatar
What I meant to say was he created that wheel (thats my motor).
Here's a vid of the lt1 on the ls1 system pictured
http://www.cz28.net/pb_cz28_lr.html
Nick
