makeing no boost
Old Nov 22, 2003 | 12:26 PM
GT40MkI's Avatar
makeing no boost
got my vortech kit on, I was seeing 4 psi but when it hit 5+ it would go to zero, now I am seeing 1psi max mostly zero
help
Old Nov 22, 2003 | 12:27 PM
GT40MkI's Avatar
also my fmu is not spikeing, I have tried 2 fmus and even a super fmu
Old Nov 22, 2003 | 04:41 PM
IDOXLR8's Avatar
It sounds to me like you are having belt slippage. If the belt is not slipping then you may have a vaccum leak.
Old Nov 23, 2003 | 06:16 PM
GT40MkI's Avatar
well no belt slippage
i think i may have a vacuum hose wrong
maybe the ones for the opti, i just left them how the were.
does anyone have pictures of the top portion
Old Nov 23, 2003 | 06:40 PM
SMOKNZ's Avatar
Ummmm,
A 1/8th inch tube isn't going to bleed all the boost from a blower...
Bill
Old Nov 23, 2003 | 09:25 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
sounds like you are possibly collapsing the intake tube, or the belt is slipping.
Old Nov 23, 2003 | 09:39 PM
boosted-lt1's Avatar
If you see NO BOOST on the gauge at all now, maybe check the line from intake to gauge. I had a tear in mine and at a certain point it showed I wasnt making anything. The way I understand , You are ssing NO positive pressure on the gauge at all .
-Scott
Old Nov 23, 2003 | 09:52 PM
engineermike's Avatar
The bypass valve could be stuck open.
Seriously, you should run the Opti vent lines how Vortech recommends. You are pressurizing you Optispark, which I'm sure it wasn't designed for.
Mike
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
LT1runner
33
Jul 24, 2002 01:19 PM
