lt4 vs lt1 block for fi
When choosing a block for a forced induction setup, is it better to find an lt1 block and convert it to 4 bolt mains or to start off with an lt4 block to begin with (or does it really matter)? Aiming for 600 rwhp.
my current block is a 4 bolt main but I want as little downtime with the car as possible but finding another 4 bolt main has been kinda tough. I had heard that 4 bolt 'splayed' can be better but haven't found any hard evidence of this.
I wold venture to say that the majority of people making significant HP with an LT-x motor have used an LT-1 block and machined the block to accept the splayed 4-bolt conversion main caps. Either are typically very reliable for big HP motors and are not the weak link in an LT-x build.
you might want to ask Advanced Tech the question on the power limits of a 2-bolt vs 4-bolt and see if your designs fall inside our outside those ranges. Boost really isn't the issue as much as raw torque and the unbalanced vibration. From your desired state of 600 RWHP, you're probably pulling 500 Ft/Lb torque and may create havoc for a 2-bolt.
DelSoto,
Search the Advanced Tech section and you can start to form an opinion. Vizard and others tend to relay that 500 flywheel HP is the safe 'limit' for a two bolt Mouse. My un-scientific notion is that 600 crank would be ok for a street car with studs and real careful setup, etc.
To go out and find a 4-bolt LTX block will likely take more time and about $200-300 more than a 2-bolt block. That is roughly half the cost of converting a 2-bolt block to splayed caps - with 3 steel caps of course. The downside could be finding a real good shop to do the conversion - correctly.
People have made big power with both straight mains and also splayed outer bolts. Some have said that straight-4 is stronger on a production block (not necessarily true with aftermarket blocks) and some say that angled outer bolts tie into the oil pan rail for more rigidity. But, you need meat in the area of the angled bolts....if your breaking into water jackets or tying into thin areas then how far ahead are you? I've read that flat bottom splayed caps are better than stepped caps. You machine the block flat and your cross-car register moves way out to the pan rail. Seems that with all of this, any solution will still allow for main-cap-walk at real high power levels. Apparently walk can occur with either straight or splayed outers (fore-aft movement of the cap). One option could be to dowl the main caps to prevent this motion. HOWEVER, the major concern will be cap-cracking between dowl and bolt hole so.......do your homework if you're going consider this.
Oh, and to answer your specific question, I say either block will ok on the street at 600hp. Your budget & project timing will dictate.
One last comment - the above information is worth about what you paid for it.
Regards,
Scott.
Regards,
Scott.
The block and related parts are not typically a problem unless you are planning a very high power setup. I have used each of the following with no problems: factory 4-bolt, factory 2-bolt to ductile iron straight 4-bolt GM cap conversion (ductile iron caps no longer made by GM), factory 2-bolt to steel cap conversion on all 5 with splayed center caps. I think the last was overkill. All of these blocks had a 1/2 fill however.
Rich
Rich
How would the have filled block run on the street. Wouldn't oil temps be dangerously high? I have heard people do 1/4 fills on a dd with no problems. So would it be worth doing the quarter fill or half fill? for an almost dd?
