Low Boost Motor build
Old Sep 18, 2003 | 09:24 AM
HawkCMC's Avatar
Hey Everyone,
Just want to see if I am correct on this, lets say I wanted to build a low boost motor like 6 or so psi. A good reliable build up would be forged pistons dropping the compression a bit and getting some better injectors correct? I am not really looking to make this thing a 9 second beast just a good amount of kick and lets face it whats better then hearing the sound of a nice american v8 exhaust followed by a loud Blow Off Valve.
Thanks for the help,
CMC
Old Sep 18, 2003 | 11:30 AM
sleeperz28's Avatar
Back when I was 18 and just bought the car I wish I would have done it different. The best most reliable route is to do heads and cam with a nice shot of juice. There are a few guys around here that have done that. The motor lasted a long time. A few guys ran a 200 shot for a while, the motor would have lasted but he blew a portion of the intake tube off. Anyway an Lt1 with heads/cam/exhaust is good for a 12.5 @~112mph. Add some juice to it and you have an easy 11 second car. After all this is done its about $1000 less then a blower so you have the money to put a good clutch in. Just my .02
Turbos and superchargers are nice but they will cost you a grip more in the long run.
Old Sep 18, 2003 | 12:59 PM
Rival's Avatar
A ls1 does a lot better stock with boost than an lt1. Since your going to drop the compression and throwing in forged slugs I think you'll be safe. Get some 42lb injectors and a good intank pump. You'll do alright
Old Sep 18, 2003 | 01:58 PM
HawkCMC's Avatar
I have a 150 wet shot and a thunder 224 cam. I want to go the blown route now. Thanks for the info I appreciate it, I figure with the pistons, the injectors and some good tuning the car should be good to go.
Old Sep 18, 2003 | 07:36 PM
BOOST FED 95Z's Avatar
Tuning is the key to make any boosted motor last.
Scott
Old Sep 18, 2003 | 08:06 PM
engineermike's Avatar
Computer comatability seems to be the problem with LS1's with superchargers. I've seen a naturally aspirated 540 rwhp LS1 easily computer tuned and a supercharged 420 rwhp LS1 with big computer problems, both at Thunder Racing.
Mike
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
transam_388
Mar 15, 2015 11:53 AM
Cam's maro
Jan 30, 2015 09:21 PM
