Looking for suggestions
Well it's all fun but I'm getting bored, so it's time to step up. I am currently in the process of building a 9" so I can get the power to the ground without breaking it. I am going to pull the motor and tear it down as well to install splayed caps, so I may as well modify it while I'm there.
My question is this:
In my setup (see signature) what would I benefit the most from:
(1) heads, long tubes, and T-trim
or
(2) Scrap the blower and go turbo, bigger injectors, and boost control.
I'm pushing towards turbo, but I would like some opinions as well!
or
or
or
If not, then you need to look at a bigger blower (like a YSi), or step into a turbo setup.
YSi and methanol injection would bring that car to life. Also you should consider a boost referenced ignition box (MSD BTM etc.) and pull timing with the box instead of your pcm timing tables. It will give you a great midrange boost in power.
I've been using basicly stock timing tables and pulling 1.5 degrees of timing for each 1 pd of boost. Its got power from 1500 all the way to 6200rpm and is very responsive on the streets. Relatively inexpensive for the amount of power that I gained.
slomarao & RealQuick, Is it ever enough? Easy answer, NO! I like big numbers. 97WS6Pilot, I realize now that I don't have it in my signature, but I am running an MSD BTM & 6AL as well. Thanks everybody for the input. I was at the dyno today and watched an LT1 383 with a 96mm turbo on low boost (8lbs.) pull 837 RWHP, but ran into some oil pressure issues before seeing any real boost. So I think I have found the way that I am gonna go. I'm thinking maybe 90mm? Go big or stay home!
Chas
Chas
Chas
Chas
honestly, what are your goals for the car? Is it going to be a street car? drag car? what
IMO, over 600RWHP is too much for the street. Thats why I am going with a small(er) turbo. It will spool faster than such a big one, and will be plenty fun for the street, and give good results at the track too. Remember, theres two parts to going fast at the track
Traction and horsepower
if you dont have traction, the HP is worthless.
Hooking 900RWHP is a lot harder than hooking 600RWHP
I plan on the street launching on wastegate(3lbs), and not touching high boost(18lbs) until 3rd gear(which should be ~100mph w/ the 3.08's).
I drew alot of attention with this one. Thanks alot guys! My goals where originally a fast street car with occasional drag race. Now I have gotten a hunger for power and I am looking more at a drag car with occasional street romp, so I would say Pro Street / Super Street. I know that you can't go fast without traction, but there are some really good sticky compound tires out there now that are "street legal". I've got a buddy that just sold his 8 second street car (Mustang) to have the rolling chassis of his next car built which is "streetable" and built for 200mph. So basically I believe that you can never go fast enough. When you break something that just means you found your weak-point!
Chas
Chas
You should take a look at the timeslips of Lisa33 or Jeff 96 SS if you don't think a supercharger will beat a turbo setup. LOL.
