Looking for pics of p600b/Install??
Thats what Im assuming. They want $1500 w/o tune in NY to install. Thats not going to happen. How did you tap your oil pan. Also how was it once she was installed. Im sure once that foot was buried into= FUN!!!
I sent u a PM, so check that out, if you have decent mechanical knowledge, a long weekend and it goes in fine, taping the pan was easy, I left the pan on the motor and just put some grease around the hole, i hit it with a punch then drilled a small pilot hole. After that i drilled it out and flushed the heck out of my pan with oil and brake cleaner then some more oil. After that i just taped the pan. Its a totally different car now, i only have the 8lb pulley on it, but its only reading around 5-6 pounds at the motor. But it's a rocket now compared to stock.
Keep looking in the "for sale" section here, they pop up all the time. Also check e-Bay. Geez, I could barely "give" mine away when I was upgrading to a larger unit a while back.
If you are looking for parts, call Bob at: http://www.exoticperformanceplus.com/ He will take good care of you.
Henson071
Dec 30, 2015 09:55 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
meissen
Aug 11, 2015 06:05 AM
cmsmith
Jul 10, 2015 07:19 PM
