Looking for a base program (LT1Edit) for 383 and 10-12#
Hi guys, I am currently building my motor. I wanted to know if anyone had a program (LT1 Edit) for a 383 and 10-12# of boost and no Fmu. I am not sure what injectors I will get so please let me know what you are running. If I can get a program with 60,65 or 72# etc. I will just purchase the corresponding injector to go with tune. I just want a ballpark area so I can break in the motor and drive it to the dyno. Thanks guys for any help to get me started. I will greatly appreciate it........John.
Re: Looking for a base program (LT1Edit) for 383 and 10-12#
Allen at http://www.caspeed.com/lt1/index.html has a bunch of programs that you will be very interested in. Your car will be similar to his setup. He was running a 383 on his 95 with no FMU with 50#/hr (close to maxing out) injectors through a S-trim.
I would email him as you are downloading his program, just out of courtesy. Remember, you should still get a dyno tune as soon as you can.
As for your injector question, I would recommend getting the www.acceleronics.com impedance box with 72#/hr injectors. This will allow you room to grow and will be fine for what you have now. I was running this setup even without my supercharger hooked up through Bay Area traffic.
383 with acceleronics and 72# semens injectors 12# D1 and spearco intercooler. I have done alot of edits, and always change something. I don't know what a base program is. Best to have version 2.2
_________________________
97ss obd2
97ss obd2
A little more info for you guys. 383,stock ported heads,220-230/116 range cam, 10-12# of boost, I would like to run 72# injectors and OBD 1. Someone has to have something. Thanks again......John
You have mail.
SVO 42# injectors, fuel pressure is 51 psi with vacuum disconected. If yours is an auto, then my stall is 2800 rpm, vigilante. This trans has lasted 2 years so far. See web page for details.
Hope this works.
LWM
Hope this works.
LWM
whitehooptie
Aug 10, 2015 07:02 AM
