Little Dyno Vid
97WS6Pilot The AI heads and intake helped alot! About 60RWHP under the Curve and around 30 peak RWHP.
roguedriver I think you would need a bigger shot
If you threw a TH400 in your RWHP would probably go down 70-100RWHP.
I made a couple shakedown passes this weekend one without spray and it resulted in a 9.7@141 hot as hell and a track that is typicly two tenths slower and 2mph than the good tracks in the area. I then tried a spray pass and I smoked the tires with the front wheels of the ground!
Thats the first time that has happened and well I almost crossed the centerline so I had to let off and correct. I shifted to second and hit it again and was sliding all over and trying to pedal to find traction when that didn't work I shifted to third and hammered it again I was almost to the 1/8 when I got traction and that pass was 10.50 at 143. I think I'll be damn close to 8s on a good track!
If you threw a TH400 in your RWHP would probably go down 70-100RWHP.I made a couple shakedown passes this weekend one without spray and it resulted in a 9.7@141 hot as hell and a track that is typicly two tenths slower and 2mph than the good tracks in the area. I then tried a spray pass and I smoked the tires with the front wheels of the ground!
My turd runs now btw, should be driveble by the end of the week, waiting on Driveshaft and shifter.
tdigger9899
Sep 7, 2015 10:56 AM
Thanks for the info.
