Liquid air intercoolers
Originally posted by Roadie
Last time I checked, water and antifreeze ran through my block. Granted, the water is cooled by air, but my engine most certainly is cooled by liquid, not air. Why??? Because liquid is a MUCH better conductor of heat.
air-to-air will never perform as well as air-to-liquid as long as the air-to-liquid setup has an adequate sized heat exchanger. That's just simple physics.
If a liquid to air heat exchanger was not more efficient than air to air, all our engines would still have big cooling fins on them and not bother running the more complicated liquid cooling system.
All this is neither here nor there, since it is down right silly to compare an 'air-cooled' engine to an air to air intercooler... While hot spots in an engine can cause problems, the hotter areas on the air to air inter cooler [entry tank, core near the entry tank] don't make a bit of difference.
The point of my previous post was that a liquid cooled intercooler is limited by its air cooled heat exchanger, and that the heat exchangers used on Li setups aren't going to pull as much heat out as a comparable air to air setup. Anyway, evaluating the proper intercooler setup requires a variable that no one else had bothered to mention - how the car is driven on the street. If the driver keeps it in boost a lot, the air to air is probably his better bet. If he only sees boost for short periods, and the heat exchanger has sufficient time to pull the heat out between those periods, than a liquid setup works just as well.
Originally posted by 97WS6SCharged
If all else fails, just stop at a jiffy store and fill up your empty big gulp cup full of ice and dump it into the water tank.
Take your pick...
Past few years:
87 T-Type turbonetics TE-62 / custom $2k intercooler made by CAS - when I first installed it, some of the old school turbo buick guys got into it with me about li intercoolers not being a streetable.
96 T/A 355, ported TFS TW LT1 heads, crane HIR (inverted flank lobes) custom turbo cam, T-76 Q-trim BB, etc. Started out with a TT air-air intercooler... sold all the intercooler/pipes to aram and intended to install the CAS setup from my Buick. I fabbed up a hard pipe from the turbo to the TB so I could keep it driving while I worked out how the CAS stuff would be installed ... and proceeded to blow up the motor w/o the intercooler.
Present project:
67 Corvette with a 383 LT1 T-80 / custom intercooler using a new toyota core I bought from Japan... core is getting air and water tanks TIG'ed on this weekend.
My wife and I are trying to put together another vacation to Japan in a month or two... Might pick up a few more intercooler cores (or anything else I can find!) if I have time. There is a lot of turbo stuff over there - it seems like a very large portion of the cars in Japan are turbocharged ... not unusual to see families driving around 4 dr sedans with large front mount intercoolers.
Past few years:
Present project:
Victor Lamb
Aug 26, 2017 02:52 PM
95chwagon
Jan 13, 2015 09:19 PM
